I'm trying to use a Metro M4 Airlift Lite, and want to use it as an access point. It's up on a pole solar/battery powered with no router in sight and I want to be able to connect to it as an access point and display the data its collected. I believe I need its ESP32 to act as a Soft Access Point Web Server mode.
I've been making a program using Arduino code (C++) and now that I have it went to configure the Airlift Lite as an Access point and have fallen short with no examples and every example I see that shows how to use an ESP32 as an access point doesn't work with it (usually saying SoftAP doesn't exist in the library or no wifi_shield found).
Can someone show an example of using the Metro M4 Airlift Lite as an access point (in Arduino/C++ not circuit python)? Thanks
How to get Metro M4 Airlift Lite to be access point?
- MonsignorBart
- mikeysklar
Re: How to get Metro M4 Airlift Lite to be access point?
@MonsignorBart,
The adafruit WiFiNINA AP example was designed to work with AirLifts.
https://github.com/adafruit/WiFiNINA/tr ... eWebServer
Also as you probably have observed there is good support for access point mode on the CircuitPython side using the esp32spi library with AirLift hardware.
https://circuitpython.readthedocs.io/_/ ... atest/pdf/
- MonsignorBart
Thank you so much! I had to make modifications to get it working, (at end of this) but it is working now and I have a foot in the door and should be able to do the rest. I'm very happy.
I looked at doing this in circuit python, and came across the document you mentioned and many others but every esp32spi example seems to get information from an external website and shows it on the serial monitor when I needed a sample that posted the responses to an html file that I could interact with. The closest example in circuit python I found was https://github.com/adafruit/Adafruit_CircuitPython_WSGI which showed me how to create an AP with circuit python, but once I did that I couldn't figure out how that program worked nor how to turn it into an interactive html document instead of a fixed index.html that must exist already and never updated. Maybe someone more knowledgeable would be able to take those examples and with a library spec figure out how to adapt them to be an interactive html document instead of to the serial monitor but "I'm not a smart man" lol. But, again I'm very happy to get something working so I can continue and greatly appreciate you helping me.
In Arduino (C++) Here's the changes necessary to get it working with an Metro M4 Airlift Lite.
I was getting a PinStatus does not name a type. I had to follow the directions at https://github.com/arduino-libraries/Wi ... 89928621fb which states to open src/utility/wifi_drv.cpp and change the line
and open src/utility/wifi_drv.h and change
lastly in the code it ran but was giving an error saying unable to create access point. Doing some research I found out my SSID had to be at least 8 characters long. Once I did the above it worked!
PinStatus WiFiDrv::digitalRead(uint8_t pin) // around line 1063
to
#if defined(ARDUINO_ARCH_MBED)
#else
int WiFiDrv::digitalRead(uint8_t pin)
#endif
static PinStatus digitalRead(uint8_t pin); // around line 293
to
#else
static int digitalRead(uint8_t pin);
#endif
- mikeysklar
Okay, so set digitalRead to return type int and an 8 character SSID. Good job getting everything going so quickly.
