Itsy Bitsy m0 Express Maybe got a defective unit
Daft_vagabond
Post by Daft_vagabond »
It was recommended that I bring up concerns about a defective unit here.
I received my order yesterday and started trying to use it today. At first, the default files kicked in and flashed the onboard neopixel a few different colors, but once I loaded my own files onto it, I couldn't get a response. After that I went through all the troubleshooting steps you might expect, firmware, drives, different USB cable, rebooting everything, ect. I still couldn't get me code to run, so, just in-case it was my code, I decided to try out some of the example codes from here on the website, still nothing. I just tried one last time to run one of the servo sweeping examples and I noticed little sparks coming form the USB pin and I had no choice but to quickly unplug it form my PC.
I'm not certain what to do. But I appreciate any help.
dastels
Re: Itsy Bitsy m0 Express Maybe got a defective unit
Post by dastels »
Are you using CircuitPython? If so, what are you naming the code files on the CIRCUITPY drive?
Daft_vagabond
Sorry for the late replay, really. I didn't get an alert for some reason.
"main.py" is the name I'm using currently, though I've tried the other defaults.
dastels
Post by dastels »
That shoudl be cood. Just be sure that there is only one of main.py, main.txt, code.py, code.txt and maybe some others with a basename of main or code. It looks in a particular order and tries the first it finds.
Can you try a simple blink example?
import board
import digitalio
import time
led = digitalio.DigitalInOut(board.LED)
led.direction = digitalio.Direction.OUTPUT
while True:
    led.value = True
    time.sleep(0.5)
    led.value = False
    time.sleep(0.5)
Daft_vagabond
Sorry for the confusion. In the couple days that I didn't receive a notification, I decided to reach out with a more post that more elaborately described my situation.
Since then this issue has been resolved but I appreciate your assistance regardless, thank you.
Next time I'll be certain to check in more frequently and to be less reliant on automated notifications
Return to “Itsy Bitsy Boards”
