Thanks for quickly trying the provided code.
The second pulse looks closer to the expected value.
If you only print out pulses[1] ignoring the pulses[0] does that start to provide pulseIn data that is matching to your Arduino.
Arduino to Circuitpython code conversion
- mikeysklar
- Daft_vagabond
Re: Arduino to Circuitpython code conversion
The results are nearly the same
Which doesn't surprise me, as I think as the array fills up, they just start to cycle through, right?
27
27
27
27
27
27
27
27
28
27
28
9
19
11
17
17
7
27
27
27
27
28
28
28
27
8
8
27
28
11
27
27
27
27
27
7
7
27
27
27
28
13
27
28
22
7
27
28
27
27
28
28
28
7
9
28
8
28
7
10
27
27
7
28
6
27
28
27
6
27
27
28
27
27
28
27
27
28
6
27
28
27
9
17
8
28
8
7
27
28
28
27
28
27
27
27
28
7
7
8
28
27
28
28
27
27
7
17
27
10
27
17
27
27
- mikeysklar
Looking through the docs for pulseio.PulseIn() one thing that stands out is pulse.resume(80) using a trigger pulse.
It would probably be best not to pass pulse.resume(80). btw in you last code example code paste it looks like you might have dropped pulse.resume()? I did not see the last line after the comment.
https://circuitpython.readthedocs.io/en ... s/pulseio/Using trigger pulse with a device that drives both high and low signals risks a short. Make sure your device is open drain (only drives low) when using a trigger pulse. You most likely added a “pull-up” resistor to your circuit to do this.
- Daft_vagabond
Would you mind Eli 5ing that for me? (Other than the part about the pull up/pull down resistor, I understand that that is just a resistor that is only strong enough to influence the logic in one direction or the other while the signal is idle)
- mikeysklar
I'd like you to try to use pulse.resume() with no arguments. Get the 80 out of there. That '80' value is for an optional trigger pulse and I don't think that is helpful in your case.
- Daft_vagabond
Oh, yeah, I hadn't been using the (80) parts. I thought that by introducing more pulses, it'd only further throw off my readings.
- mikeysklar
@Daft_vagabond,
Looking at the github repo for PulseIO (PulseIn) for CircuitPython an issue stands out as you are attempting to measure < 10us pulses.
"PulseIn drops very short pulses #4946"
https://github.com/adafruit/circuitpython/issues/4946
- Daft_vagabond
I'm guessing Arduino/C++ doesn't have this issue?
Since I'm not measuring IR, would it be simple enough to lower the minimum?
In that thread, DavePutz mentions it as a possibility.
https://github.com/adafruit/circuitpyth ... -872975351
- Daft_vagabond
Or even, could we add a parameter that can control the minimum lengths or even turn them off.
- mikeysklar
@Daft_vagabond,
That seems reasonable to me. There is a maxlen parameter why not have a minlen so these short pulses can be caught.
Would you like to suggest that on the open issue?
In terms of a shorter term work around I don't see an obvious setting in the CircuitPython PulseIn to adjust for minimums. You might be able to get something going based rp2pio / adafruit_pioasm examples here:
https://github.com/adafruit/circuitpython/issues/4983
- Daft_vagabond
I posted a comment on the open issues you linked to. Lets hope this is something that can be implemented. It would open up an array of uses outside of IR-related projects.
