Lets say I have a "main" while True-loop that reads an input, like a switch, and makes an led flash at a certain rate. Could I write a forever-loop that waits for a different input, like a button to be pressed, and once pressed it takes priority over the first loop and starts flashing the same led at a different rate, at least until the button was released?
Lets also say that, for this example, the "main" loop also drove some other peripherals. I wouldn't want the second loop to stop the main one, just to temporarily drive the led differently and leave the other peripherals to continue to be driven by the main loop.
Can one prioritize a loop?
- dastels
Re: Can one prioritize a loop?
If you are using CircuitPython: No. It's not a multi tasking system so you can't have two loops running at the same time. Ther are programming techniques that can achieve a similar result. See https://learn.adafruit.com/multi-taskin ... cuitpython.
- Daft_vagabond
So the
def on_forever():
doesn't apply here?
I'll check out that link in the meantime.
def on_forever():
doesn't apply here?
- dastels
That's from Makecode. Not applicable in CircuitPython.
