Same code working on bluetooth module connected to arduino b
snisal
Post by snisal »
I am using a feather 32u4 microcontroller bought from Core Electronics. The same code that I was using on an arduino uno/mega with a bluetooth module connected does not seem to work on the adafruit feather 32u4. I am using a Unity3D app for the bluetooth communication, with this plugin, and the following arduino code:
#define Pin1 9
#define Pin2 10
#define Pin3 11
#define Pin4 12
char data = 0;
char EMSOn = HIGH;
char EMSOff = LOW;
void setup()
  pinMode(Pin1, OUTPUT);
  pinMode(Pin2, OUTPUT);
  pinMode(Pin3, OUTPUT);
  pinMode(Pin4, OUTPUT);
  digitalWrite(Pin1, EMSOff);
  digitalWrite(Pin2, EMSOff);
  digitalWrite(Pin3, EMSOff);
  digitalWrite(Pin4, EMSOff);
void loop()
  if (Serial.available() > 0)
data = Serial.read();
Serial.print(data);
Serial.print("\n");
if (data == 'A')
digitalWrite(Pin1, EMSOn);
else if (data == 'a')
else if (data == 'B')
digitalWrite(Pin2, EMSOn);
else if (data == 'b')
else if (data == 'C')
digitalWrite(Pin3, EMSOn);
else if (data == 'c')
else if (data == 'D')
else if (data == 'd')
Return to “Itsy Bitsy Boards”
