Launch Deck Code
Egauss
Launch Deck Code
Post by Egauss »
Hello, i am trying to run launch deck hid keypad code "https://learn.adafruit.com/launch-deck- ... cuitpython" on itsybitsyM4 and have error:
File "code.py", line 87, in <module>
File "adafruit_trellism4.py", line 236, in __init__
AttributeError: 'module' object has no attribute 'NEOPIXEL'
does anyone know work around? Thanks
dastels
Re: Launch Deck Code
Post by dastels »
Make sure you have the latest CircuitPython for the board. Then grab the latest library bundle. Delete everything in CIRCUITPY/lib, and empty trash as appropriate for your OS. Then copy files/directories from the bundle to CIRCUITPY/lib as required.
That will, in my experience, typically take care of this sort of problem.
Egauss
Post by Egauss »
Sadly solution dosn helps
dastels
Post by dastels »
Ah. That code adafruit_trellism4.py is for the trellisM4 board, not the ItsyBitsy.
Egauss
Post by Egauss »
Thanks for your reply.
i did small research and looked schematic, seems neotrellis panels on i2c bus and trellis M4 works from ic pins.
Does anybody know example of hid lounch pad with i2c bus to make as normal PC keyboard. Thanks
dastels
Post by dastels »
Yes, that's the NeoTrellis 4x4 module that has an onboard SAMD9 running as a seesaw device and driven via I2C (and works with any MCU board). The NeotrellisM4 is the 4x8 grid with an onboard SAMD51 that runs the array directly.
The NeoTrellis guide is here: https://learn.adafruit.com/adafruit-neotrellis. The biggest difference from a software point of view is using a different module to interact with the button/light aray: adafruit_neotrellis instead of adafruit_trellism4. See https://learn.adafruit.com/adafruit-neo ... ython-code for more information.
Return to “Itsy Bitsy Boards”
