One of them behaves fine and I am able to flash it (e.g. run CircuitPython). However the other one I cannot manage to flash at all (using the same cables/setup that work with the first one).
It shows up as a flash drive RPI-RP2 so the bootloader is working. However whenever I try to flash anything to it by giving it a UF2 file, the drive disappears as if it's trying to flash it, and then reboots into the bootloader (i.e still shows up as RPI-RP2 as if I haven't flashed a UF2 at all)
I've tried flashing a couple different things including a couple versions of CircuitPython and Micropython, as well as running the flash_nuke.
Is there anything else I should try/that might fix it, or is it just likely dead and I should order a replacement?
INFO_UF2.txt:
UF2 Bootloader v2.0
Model: Raspberry Pi RP2
Board-ID: RPI-RP2
