M0 - Interessting upload issues
ChristianD
Post by ChristianD »
I have an interessting problem on all of my itsyBitsy M0( i tried 3 of them ) no matter which firmware (Bootloader) they have on.
If i upload the "Blink" example it works the first time. Then, if i try to upload the "Blink" example again it fails.
When this happens i get a windows error message that the USB device could not be installed.
A re-plugin of the itsy leads to the fading led and in windows it will show up the ITSYBOOT device for about 5 seconds and then the windows error message thet the USB device could not be installed pops up again. If i am very fast i can copy a new bootloader file and then the itsy will allow exactly one upload until it gets into the interessting state again.
BTW: I may use the double tap on reset while uploading from ArduinoIDE to get the blink example to upload and work again.
What could cause this issue?
Here the steps i did:
  • Plug in ItsyBitsy M0
  • Upload Blink example - Works
  • Upload Blink example again - Fails with following error:
    Set binary mode
    SAM-BA operation failed
    Send auto-baud
    Set binary mode
    readWord(addr=0)=0x20002dd8
    readWord(addr=0xe000ed00)=0x410cc601
    readWord(addr=0x41002018)=0x10010305
    version()=v1.1 [Arduino:XYZ] Jun 23 2019 17:45:14
    chipId=0x10010005
    Connected at 115200 baud
    Atmel SMART device 0x10010005 found
    write(addr=0x20004000,size=0x34)
    An error occurred while uploading the sketch
  • Itsy goes into LED Fading mode and after a while following errors pops up
  • disconnect itsy bitsy and plug in again
  • fading led mode. ITSYBOOT shows up for about 5 seconds
  • windows USB error that it could not install device
  • upload with doubletap on reset while uploading. Bloink example does sucessfully upload.
Bootloader INFO:
UF2 Bootloader v3.7.0 SFHWRO
Model: ItsyBitsy M0 Express
Board-ID: SAMD21G18A-ItsyBitsy-v0
ChriD
Re: M0 - Interessting upload issues
Post by ChriD »
Well....
I tried another PC and there it works flawlessly.
danhalbert
Post by danhalbert »
Try cleaning out your Windows USB devices on the "bad" PC: https://learn.adafruit.com/welcome-to-c ... 3094694-11
Return to “Itsy Bitsy Boards”
