wake up Itsybitsy nRF52840 by internal RTC timer?
- peterhsi75
Does anyone has an example code to wake up Itsybitsy nRF52840 Express board from “system on sleep mode” by internal RTC timers?
- mikeysklar
Re: wake up Itsybitsy nRF52840 by internal RTC timer?
Are you look for Arduino example code?
This threads should help get you started although they are not complete.
viewtopic.php?f=24&p=773895
viewtopic.php?f=25&t=188730
#include "nrf_delay.h" // ADDED: COPIED FROM NRF52 SDK
void buttonHandler() {} // ADDED: STUB
// \brief Main entry point of Arduino application
int main( void )
init();
initVariant();
#ifdef USE_TINYUSB
Adafruit_TinyUSB_Core_init();
#endif
#if CFG_DEBUG >= 3
SEGGER_SYSVIEW_Conf();
#endif
// BEGIN ADDITION
pinMode(LED_BUILTIN, OUTPUT);
nrf_gpio_cfg_sense_input(16, NRF_GPIO_PIN_PULLDOWN, NRF_GPIO_PIN_SENSE_HIGH);
attachInterrupt(digitalPinToInterrupt(16), buttonHandler, CHANGE);
while(1) {
digitalWrite(LED_BUILTIN, HIGH);
nrf_delay_ms(100);
digitalWrite(LED_BUILTIN, LOW);
nrf_delay_ms(100);
__SEV(); // create an event
__WFE(); // return immediately, clearing all events (including the one created above)
__WFE(); // wait for the next event
// END ADDITION (code below here never reached)
// Create a task for loop()
xTaskCreate( loop_task, "loop", LOOP_STACK_SZ, NULL, TASK_PRIO_LOW, &_loopHandle);
// ... rest of the core
- peterhsi75
Thank you very much for your quick response. Your sample sketch seems to rely on a hardware interrupt event. Am I correct?
Yes, I am looking for Arduino code.
I need to wake up a battery powered sensor every hour to take a reading then go back to deep sleep. I do not have access to the board to press a key or other hardware to trigger a hardware interrupt event. It has to rely on an internal timer event to wake up.
I implemented another sketch based on example code of /esp32/deepsleep/timerwakeup.ino for an esp32 board and it worked perfectly. I only need to include two functions:
setup(){
esp_sleep_enable_timer_wakeup(TIME_TO_SLEEP * uS_TO_S_FACTOR);
loop() {
esp_deep_sleep_start();
In your example sketch, the 3 functions of _SEV(); _WFE(); _WFE(); is similar to esp_deep_sleep_start() function, right?
But, how to setup a timer event (i.e. define the timer interval - similar to esp_sleep_enable_timer_wakeup() function)?
setup(){
loop() {
- mikeysklar
The second link originally provided was clock based interrupt wakeup. I believe this code was having some issues, but might be worth reviewing.
#include <RTClib.h>
#include <Wire.h>
#include <wiring.h>
RTC_DS3231 rtc;
// the pin that is connected to SQW
#define CLOCK_INTERRUPT_PIN 6
//uint32_t pin=6;
uint8_t wake_logic = 0;
volatile byte state = LOW;
void setup()
// while(!Serial) delay(10);
if (!rtc.begin()) {
Serial.println("Couldn't find RTC!");Serial.flush(); while (1) delay(10);
if (rtc.lostPower()) {
// this will adjust to the date and time at compilation
rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
//we don't need the 32K Pin, so disable it
rtc.disable32K();
// Making it so, that the alarm will trigger an interrupt
pinMode(CLOCK_INTERRUPT_PIN, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(CLOCK_INTERRUPT_PIN), onAlarm, FALLING);
// set alarm 1, 2 flag to false (so alarm 1, 2 didn't happen so far)
// if not done, this easily leads to problems, as both register aren't reset on reboot/recompile
rtc.clearAlarm(1);
rtc.clearAlarm(2);
// stop oscillating signals at SQW Pin
// otherwise setAlarm1 will fail
rtc.writeSqwPinMode(DS3231_OFF);
// turn off alarm 2 (in case it isn't off already)
// again, this isn't done at reboot, so a previously set alarm could easily go overlooked
rtc.disableAlarm(2);
// schedule an alarm 10 seconds in the future
if (!rtc.setAlarm1(
rtc.now() + TimeSpan(0, 0, 0, 10),
DS3231_A1_Second// this mode triggers the alarm when the seconds match. See Doxygen for other options
Serial.println("Error, alarm wasn't set!");
} else {
Serial.println("Alarm will happen in 10 seconds!");
//wake logic is set to 0 in my case
systemOff(CLOCK_INTERRUPT_PIN, wake_logic);
void loop()
// Serial.println("Going To sleep");
//wake on logic 0;
digitalWrite(LED_BUILTIN, state);
Serial.println("Test");
// print current time
char date[10] = "hh:mm:ss";
rtc.now().toString(date);
Serial.print(date);
// the value at SQW-Pin (because of pullup 1 means no alarm)
Serial.print(" SQW: ");
Serial.print(digitalRead(CLOCK_INTERRUPT_PIN));
// whether a alarm happened happened
Serial.print(" Alarm1: ");
Serial.print(rtc.alarmFired(1));
// resetting SQW and alarm 1 flag
// using setAlarm1, the next alarm could now be configurated
if (rtc.alarmFired(1)) {
rtc.clearAlarm(1);
Serial.println("Alarm cleared");
rtc.disableAlarm(1);
Serial.println("RECONFIGURING ALARM");
rtc.setAlarm1(rtc.now() + TimeSpan(0, 0, 0, 10),DS3231_A1_Second);
delay(2000);
void onAlarm()
state = !state;
Serial.println("Alarm occured ! AWAKE NOW ");
- peterhsi75
Thanks again for your sample sketch. This sketch seems to rely on an external DS3232 RTC device. I was hoping to use the built-in RTC counter of nRF52840.
- mikeysklar
I've not seen the internal RTC successfully used with the nRF52840. There is some discussion here about the issues around it and yes another code sample.
viewtopic.php?f=24&t=175815
