I have created a custom pcb for a project and have the Itsy Bitsy soldered to it. If I run the code though a USB plugged into the Itsy Bitsy all works well. If I unplug the usb and put it into the USB I have on my pcb it fails after a while with the red LED flashing twice.
I am unable to fault find as I don't have any output as my USB is only 5V and 0V - it is the same lead attached to my PC.
I seem to remember having a similar problem when I tried powering the Itsy Bitsy off a power only 5V supply. Is something trying to communicate with my PC or is it a hardware problem? My code isn't trying to communicate but it could be one of the libraries?
I have the boot code installed to allow writing to a file and these libraries:
import rotaryio
import board
import digitalio
import neopixel
from time import sleep
If the communication is not a problem I can post more details of the code and my pcb schematic
Custom pcb failing Itsy Bitsy M0
- alpierce
Re: Custom pcb failing Itsy Bitsy M0
You will need to post the code you are running and a schematic of the custom pc board to show how it is connected to the microcontroller.
- Franklin97355
- rubble
I now have it working through the custom pcb micro USB by connecting the USB pin on the microprocessor to the custom pcb +5V ( which is also connected to th BAT pin! )
It is a pain to keep connecting a pin to ground and disconnecting it every time I want to write updated code to the board. Also if I forget to power down the micro before adding/removing the jumper it corrupts the file system and I have to re install it.
I have also noticed a soft restart is not the same as a power down restart which caused a lot of confusion.
