I want to put the led screen and the M4 board inside a custom-built box so I won't plug the M4 directly on the back of the screen. What kind of connection cable do I have to use? Appreciate if you can point me to a link. Thank you!
Matrix portal m4 cable question
- mikeysklar
Re: Matrix portal m4 cable question
@jay_py,
This 2x8 ribbon cable is what is generally used by for RGB Matrices and I expect it to work with the HUB75 connector on the back of the Matrix Portal.
https://www.adafruit.com/product/4170
- Tortilla
I just did this with my own custom enclosure. The Matrix Portal board has a female pin header and the LED panel has male pin headers. Therefore, you will need a 16-P ribbon cable that has a male connector on one end and a female connector on the other end. I made up my own cable by purchasing the ribbon cable, male connectors and female connectors on Amazon. The connectors are super easy to install. There are youtube videos that show how to do it. You just need some way to press the connectors on to the ribbon cable. I used the vice attached to my workbench, but I think you could also use a C-clamp and two pieces of wood to apply equal pressure to the connectors. The ribbon cable can be cut to whatever length you need with a pair of common scissors. This is an advantage over buying ready-made cables because you can make the cable fit inside a cramped enclosure. I'm not sure if Adafruit will allow me to post links, but you can just search for the parts you need on Amazon. The ribbon cable that comes with the LED panels cannot be used because it has a female pin header on both ends of the cable. Good luck.jay_py wrote:Hi,
