Hey, I am currently using Itsybitsy nrf52840 with OLED and ADC module. There are times it runs without issues, and times when I get the issue with response below.
Not sure how to resolve this??
OSError: Errno 19 Unsupported operation
- RainySun
- Attachments
- Current Issue.JPG (65.77 KiB) Viewed 201 times
- adafruit_support_carter
Re: OSError: Errno 19 Unsupported operation
Most likely an intermittent connection issue.
What ADS1x15 breakout are you using and how is it connected to the Itsy?
- RainySun
I am using ADS1115 - https://www.adafruit.com/product/1085, and I have connected SCL and SDA pin of Itsy bitsy nrf52840 to SCL and SDA of ADS1115 and using A0 of ADS1115.
SCL/SDA are the I2C pins to use, but could be something specific to your setup. Please post a photo of your setup showing how everything is connected and we'll take a look.
- RainySun
Hey, Attached below is my current schematic.
I have just realized that the issue could be related to logic level incompatibility.
ADS1115 is powered by a 5V supply; not sure if that would cause the logic level to be 5V as well...
I bought the OLED from https://www.waveshare.com/1.5inch-oled-module.htm
It is 3.3V compatible, and can be powered with a 5V supply.
Schematic of OLED: https://www.waveshare.net/w/upload/a/a3 ... ematic.pdf
I will try to add a Logic level birdirection 3.3V to 5V converter between Itsy bitsy nrf52840 and ADS1115, and see if that fixes the issue.
If there is anything I am missing, please let me know.
- Attachments
- I2C.PNG (557.75 KiB) Viewed 135 times
Please follow this guide:
https://learn.adafruit.com/adafruit-4-c ... s/overview
and connect only the ADS1115 to your setup per the wiring shown here:
https://learn.adafruit.com/adafruit-4-c ... cuitpython
and then try the simpletest example from the library:
https://github.com/adafruit/Adafruit_Ci ... pletest.py
- RainySun
I used a logic level converter 3.3V to 5V on ADS1115, and it worked.
I tested the ADS1115 without the logic level converter on a new breadboard, and that worked as well.
I guess the "Errno 19 Unsupported Operation" was likely due to a connection issue.
Thank you
Thank you
