Matrix Portal M2 I2C NeoTrellis
ntynen
Post by ntynen »
I'm trying to attach a NeoTrellis keyboard to my Matrix Portal M4 via I2C.
I'm using a 4 pin JST PH to 4 pin JST SH cable.
I've connected to NeoTrellis to the M4 and, using a multimeter, confirmed that the board is getting 3.3V.
However, when I run the code to test the board I get this error:
code.py output:
File "code.py", line 27, in <module>
File "adafruit_neotrellis/neotrellis.py", line 60, in __init__
File "adafruit_seesaw/keypad.py", line 67, in __init__
File "adafruit_seesaw/seesaw.py", line 140, in __init__
ValueError: No I2C device at address: 0x2e
Running an I2C scan gives me the same output whether the Neotrellis is connected to the board or not:
>>> import board
>>> import busio
>>> i2c = busio.I2C(board.SCL, board.SDA)
>>> while not i2c.try_lock():
...     pass
>>> i2c.scan()
[25]
25 (decimal) is 0x19, the accelerometer
I've been searching the forums, the closest I come to what I'm seeing is this post: PN532 on Matrix Portal M4 (viewtopic.php?f=62&t=190458&p=921992&hi ... 2c#p921992). However, there was no resolution.
Looking for advice on what I can try next.
I've attached a photo of the NeoTrellis connected to the M4.
Any help is appreciated.
Thanks,
Nicole
dastels
Re: Matrix Portal M2 I2C NeoTrellis
Post by dastels »
That should be good. Have you tried using board.STEMMA_I2C() in place of busio.I2C(board.SCL, board.SDA)?
It's not clear from the photo that the blue wire is connected to the STEMMA-QT connector. It's probably just obscured, but worth asking about.
ntynen
Post by ntynen »
I hadn't tried board.STEMMA_I2C() yet.
I did that just now but still only getting the accelerometer.
Adafruit CircuitPython 7.3.0 on 2022-05-23; Adafruit Matrix Portal M4 with samd51j19
>>> import board
>>> i2c = board.STEMMA_I2C()
...     pass
>>> i2c.scan()
[25]
>>> i2c.scan()
[25]
Attaching a new image to show the wires better. Based on the pinouts for the M4 the wires are correct.
Anything else I can try?
Thanks for your help.
dastels
Post by dastels »
Yeah, STEMMA_I2C should be identical.
Yes, the cable is good. Have you tried reseating both ends of it?
Have you tried the matrix board with a different controller?
ntynen
Post by ntynen »
I have reseated the cable, both ends, multiple times with no change in behavior.
I receive my second Matrix Portal M4 today and it also does not see the NeoTrellis board.
I'm expecting a second I2C device within in the next day or two. At that time I can see if either board can see the new device when connected.
If there's anything else I should try, please let me know.
Thanks for the continued support.
Nicole
dastels
Post by dastels »
I just connected a STEMMA-QT temperature sensor to a MatrixPortal and it finds it without problem.
My thought is that it's your NeoTrellis board. Does the soldering on the connector on it look good?
If both portals can see the new board you get, then it's pretty conclusive that it's the NeoTrellis board.
ntynen
Post by ntynen »
Sorry for the delay in updating.
I didn't have the right cable for the NeoKey board.
I received the proper cable yesterday and connected it and I do see it!
...     pass
>>> i2c.scan()
[25, 48]
Not sure what is going on with the NeoTrellis. I'll have to try to connect it to one of my other boards and see if it's recognized there.
Do you have any other thoughts/suggestions for testing the NeoTrellis board?
Thanks,
Nicole
dastels
Post by dastels »
The code at https://learn.adafruit.com/adafruit-neo ... ython-code would serve as a good test.
Return to “Itsy Bitsy Boards”
