Metro Mini Problem Uploading to the board
by mtmotoheads on Thu Sep 13, 2018 1:53 pm
So I purchased 2 Adafruit Metro Mini's (ORDER #1847717-9774407810) the other day and finally got them. One of which works great plugged in downloaded all drivers noted and works like a charm. The other one will not take an upload. Same computer same software same cable. I ran the Adafruit Drivers Package, I have downloaded the drivers from Silicon Labs and the FTDI Chip Drivers. I have tried everything anyone has said online to get the Arduino IDE to work with it. It lights up with power light and the L red LED blinks but when trying to upload I get this...
Arduino: 1.8.7 (Windows Store 1.8.15.0) (Windows 10), Board: "Arduino/Genuino Uno"
Sketch uses 1196 bytes (3%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x55
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x55
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x55
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x55
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x55
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x55
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x55
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x55
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x55
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x55
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
I have tried on different computers different data cables nothing is working. Please help this is a big project and I need to get it working. Thanks.
The back of the chip has: ATmega328 @16MHz Vin:5-16VDC XML-2 E315391 94V-0 32 18
mtmotoheads
Re: Metro Mini Problem Uploading to the board
by adafruit_support_carter on Thu Sep 13, 2018 1:56 pm
Do you see the CP2104 show up in device manager when you plug the board in?
by mtmotoheads on Thu Sep 13, 2018 3:22 pm
I get Silicon Labs CP210X USB to UART Bridge (COM5)
mtmotoheads
by adafruit_support_carter on Thu Sep 13, 2018 7:53 pm
OK. It's seeing the USB to serial chip. That parts good. Try this - do this with both boards. There are two LEDs labeled TX and RX:
https://learn.adafruit.com/adafruit-met ... s#leds-2-9
Go through the process of trying to upload the Blink example to each board and describe what happens with these two LEDs.
Working board = ?
Problem board =?
by mtmotoheads on Fri Sep 14, 2018 2:18 pm
Ok on the good board the L blinks than both the TX and RX blink together 1 than 1 than 3 times. Code is uploaded and the L blinks on and off. The not working one when trying to upload L fast blinks 3 times than TX slow blinks 3 times than blinks once ever 10 sec as its trying to load than after a while I get "Problem uploading to board" error. The L LED does blink on and off but it always has and has never been able to take an upload.
mtmotoheads
by adafruit2 on Fri Sep 14, 2018 3:19 pm
ok lets replace the metro mini and see if that helps - email support@adafruit with a link to this thread for a new metro mini!
adafruit2
Site Admin
by mtmotoheads on Fri Sep 14, 2018 3:37 pm
Ok Will do thanks.
mtmotoheads
