express programming issues
- Clayface
im trying to do a simple strand test.the sketch will not upload,many error messages-random message "error downloading https://adafruit.github.io/arduino-boar ... index.json ".im using latest ide,any driver i could find-i cannot find my board and have tried uploading as a few different m0 boards and arduino/genuino uno but no success.ive been through the tutorial countless times,i feel like im missing something somewhere.im running an older laptop with windows 8.1. I apologize before hand,im hardly a programmer,very entry level...
Re: express programming issues
Post the exact set of error messages you get from the Arduino IDE between CODE tags please.
- Clayface
Arduino: 1.8.7 (Windows 8.1), Board: "Arduino M0"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\clayton\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\clayton\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\clayton\Documents\Arduino\libraries -fqbn=arduino:samd:mzero_bl -ide-version=10807 -build-path C:\Users\clayton\AppData\Local\Temp\arduino_build_590220 -warnings=none -build-cache C:\Users\clayton\AppData\Local\Temp\arduino_cache_444547 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\clayton\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.0 -prefs=runtime.tools.arduinoOTA-1.2.0.path=C:\Users\clayton\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.0 -prefs=runtime.tools.bossac.path=C:\Users\clayton\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.7.0 -prefs=runtime.tools.bossac-1.7.0.path=C:\Users\clayton\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.7.0 -prefs=runtime.tools.CMSIS-Atmel.path=C:\Users\clayton\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.1.0 -prefs=runtime.tools.CMSIS-Atmel-1.1.0.path=C:\Users\clayton\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.1.0 -prefs=runtime.tools.CMSIS.path=C:\Users\clayton\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0 -prefs=runtime.tools.CMSIS-4.5.0.path=C:\Users\clayton\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0 -prefs=runtime.tools.openocd.path=C:\Users\clayton\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.9.0-arduino6-static -prefs=runtime.tools.openocd-0.9.0-arduino6-static.path=C:\Users\clayton\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.9.0-arduino6-static -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\clayton\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1 -prefs=runtime.tools.arm-none-eabi-gcc-4.8.3-2014q1.path=C:\Users\clayton\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1 -verbose C:\Users\clayton\Documents\Arduino\libraries\Adafruit_DotStar\examples\strandtest\strandtest.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\clayton\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\clayton\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\clayton\Documents\Arduino\libraries -fqbn=arduino:samd:mzero_bl -ide-version=10807 -build-path C:\Users\clayton\AppData\Local\Temp\arduino_build_590220 -warnings=none -build-cache C:\Users\clayton\AppData\Local\Temp\arduino_cache_444547 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\clayton\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.0 -prefs=runtime.tools.arduinoOTA-1.2.0.path=C:\Users\clayton\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.0 -prefs=runtime.tools.bossac.path=C:\Users\clayton\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.7.0 -prefs=runtime.tools.bossac-1.7.0.path=C:\Users\clayton\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.7.0 -prefs=runtime.tools.CMSIS-Atmel.path=C:\Users\clayton\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.1.0 -prefs=runtime.tools.CMSIS-Atmel-1.1.0.path=C:\Users\clayton\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.1.0 -prefs=runtime.tools.CMSIS.path=C:\Users\clayton\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0 -prefs=runtime.tools.CMSIS-4.5.0.path=C:\Users\clayton\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0 -prefs=runtime.tools.openocd.path=C:\Users\clayton\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.9.0-arduino6-static -prefs=runtime.tools.openocd-0.9.0-arduino6-static.path=C:\Users\clayton\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.9.0-arduino6-static -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\clayton\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1 -prefs=runtime.tools.arm-none-eabi-gcc-4.8.3-2014q1.path=C:\Users\clayton\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1 -verbose C:\Users\clayton\Documents\Arduino\libraries\Adafruit_DotStar\examples\strandtest\strandtest.ino
Using board 'mzero_bl' from platform in folder: C:\Users\clayton\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.19
Using core 'arduino' from platform in folder: C:\Users\clayton\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.19
Detecting libraries used...
"C:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10807 -DARDUINO_SAM_ZERO -DARDUINO_ARCH_SAMD -D__SAMD21G18A__ -mthumb -DUSB_VID=0x2a03 -DUSB_PID=0x804e -DUSBCON "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino M0\"" "-IC:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.1.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.6.19\\cores\\arduino" "-IC:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.6.19\\variants\\arduino_mzero" "C:\\Users\\clayton\\AppData\\Local\\Temp\\arduino_build_590220\\sketch\\strandtest.ino.cpp" -o nul
avrdude: ser_recv(): programmer is not responding
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
"C:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10807 -DARDUINO_SAM_ZERO -DARDUINO_ARCH_SAMD -D__SAMD21G18A__ -mthumb -DUSB_VID=0x2a03 -DUSB_PID=0x804e -DUSBCON "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino M0\"" "-IC:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.1.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.6.19\\cores\\arduino" "-IC:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.6.19\\variants\\arduino_mzero" "-IC:\\Users\\clayton\\Documents\\Arduino\\libraries\\Adafruit_DotStar" "C:\\Users\\clayton\\AppData\\Local\\Temp\\arduino_build_590220\\sketch\\strandtest.ino.cpp" -o nul
"C:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10807 -DARDUINO_SAM_ZERO -DARDUINO_ARCH_SAMD -D__SAMD21G18A__ -mthumb -DUSB_VID=0x2a03 -DUSB_PID=0x804e -DUSBCON "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino M0\"" "-IC:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.1.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.6.19\\cores\\arduino" "-IC:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.6.19\\variants\\arduino_mzero" "-IC:\\Users\\clayton\\Documents\\Arduino\\libraries\\Adafruit_DotStar" "-IC:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.6.19\\libraries\\SPI" "C:\\Users\\clayton\\AppData\\Local\\Temp\\arduino_build_590220\\sketch\\strandtest.ino.cpp" -o nul
Using cached library dependencies for file: C:\Users\clayton\Documents\Arduino\libraries\Adafruit_DotStar\Adafruit_DotStar.cpp
Using cached library dependencies for file: C:\Users\clayton\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.19\libraries\SPI\SPI.cpp
Generating function prototypes...
"C:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10807 -DARDUINO_SAM_ZERO -DARDUINO_ARCH_SAMD -D__SAMD21G18A__ -mthumb -DUSB_VID=0x2a03 -DUSB_PID=0x804e -DUSBCON "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino M0\"" "-IC:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.1.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.6.19\\cores\\arduino" "-IC:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.6.19\\variants\\arduino_mzero" "-IC:\\Users\\clayton\\Documents\\Arduino\\libraries\\Adafruit_DotStar" "-IC:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.6.19\\libraries\\SPI" "C:\\Users\\clayton\\AppData\\Local\\Temp\\arduino_build_590220\\sketch\\strandtest.ino.cpp" -o "C:\\Users\\clayton\\AppData\\Local\\Temp\\arduino_build_590220\\preproc\\ctags_target_for_gcc_minus_e.cpp"
AVR Part : ATmega2560
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 8 0 no 4096 8 0 9000 9000 0x00 0x00
flash 65 10 256 0 yes 262144 256 1024 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500V2
Description : Atmel STK500 Version 2.x firmware
Programmer Model: Unknown
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\clayton\\AppData\\Local\\Temp\\arduino_build_590220\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10807 -DARDUINO_SAM_ZERO -DARDUINO_ARCH_SAMD -D__SAMD21G18A__ -mthumb -DUSB_VID=0x2a03 -DUSB_PID=0x804e -DUSBCON "-DUSB_MANUFACTURER=\"Unknown\"" "-DUSB_PRODUCT=\"Arduino M0\"" "-IC:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.1.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.6.19\\cores\\arduino" "-IC:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.6.19\\variants\\arduino_mzero" "-IC:\\Users\\clayton\\Documents\\Arduino\\libraries\\Adafruit_DotStar" "-IC:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.6.19\\libraries\\SPI" "C:\\Users\\clayton\\AppData\\Local\\Temp\\arduino_build_590220\\sketch\\strandtest.ino.cpp" -o "C:\\Users\\clayton\\AppData\\Local\\Temp\\arduino_build_590220\\sketch\\strandtest.ino.cpp.o"
Compiling libraries...
Compiling library "Adafruit_DotStar"
Using previously compiled file: C:\Users\clayton\AppData\Local\Temp\arduino_build_590220\libraries\Adafruit_DotStar\Adafruit_DotStar.cpp.o
Compiling library "SPI"
Using previously compiled file: C:\Users\clayton\AppData\Local\Temp\arduino_build_590220\libraries\SPI\SPI.cpp.o
Compiling core...
Using previously compiled file: C:\Users\clayton\AppData\Local\Temp\arduino_build_590220\core\variant.cpp.o
Using precompiled core: C:\Users\clayton\AppData\Local\Temp\arduino_cache_444547\core\core_arduino_samd_mzero_bl_16e9efdc3d6c3af82e42fb67c093acc5.a
Linking everything together...
"C:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-gcc" "-LC:\\Users\\clayton\\AppData\\Local\\Temp\\arduino_build_590220" -Os -Wl,--gc-sections -save-temps "-TC:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.6.19\\variants\\arduino_mzero/linker_scripts/gcc/flash_with_bootloader.ld" "-Wl,-Map,C:\\Users\\clayton\\AppData\\Local\\Temp\\arduino_build_590220/strandtest.ino.map" --specs=nano.specs --specs=nosys.specs -mcpu=cortex-m0plus -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -o "C:\\Users\\clayton\\AppData\\Local\\Temp\\arduino_build_590220/strandtest.ino.elf" "C:\\Users\\clayton\\AppData\\Local\\Temp\\arduino_build_590220\\sketch\\strandtest.ino.cpp.o" "C:\\Users\\clayton\\AppData\\Local\\Temp\\arduino_build_590220\\libraries\\Adafruit_DotStar\\Adafruit_DotStar.cpp.o" "C:\\Users\\clayton\\AppData\\Local\\Temp\\arduino_build_590220\\libraries\\SPI\\SPI.cpp.o" "C:\\Users\\clayton\\AppData\\Local\\Temp\\arduino_build_590220\\core\\variant.cpp.o" -Wl,--start-group "-LC:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Lib/GCC/" -larm_cortexM0l_math -lm "C:\\Users\\clayton\\AppData\\Local\\Temp\\arduino_build_590220/..\\arduino_cache_444547\\core\\core_arduino_samd_mzero_bl_16e9efdc3d6c3af82e42fb67c093acc5.a" -Wl,--end-group
"C:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-objcopy" -O binary "C:\\Users\\clayton\\AppData\\Local\\Temp\\arduino_build_590220/strandtest.ino.elf" "C:\\Users\\clayton\\AppData\\Local\\Temp\\arduino_build_590220/strandtest.ino.bin"
"C:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom "C:\\Users\\clayton\\AppData\\Local\\Temp\\arduino_build_590220/strandtest.ino.elf" "C:\\Users\\clayton\\AppData\\Local\\Temp\\arduino_build_590220/strandtest.ino.hex"
Using library Adafruit_DotStar at version 1.0.4 in folder: C:\Users\clayton\Documents\Arduino\libraries\Adafruit_DotStar
Using library SPI at version 1.0 in folder: C:\Users\clayton\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.19\libraries\SPI
"C:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-size" -A "C:\\Users\\clayton\\AppData\\Local\\Temp\\arduino_build_590220/strandtest.ino.elf"
Sketch uses 12208 bytes (4%) of program storage space. Maximum is 262144 bytes.
Forcing reset using 1200bps open/close on port COM5
processing.app.debug.RunnerException
at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:160)
at cc.arduino.UploaderUtils.upload(UploaderUtils.java:82)
at processing.app.SketchController.upload(SketchController.java:736)
at processing.app.SketchController.exportApplet(SketchController.java:703)
at processing.app.Editor$DefaultExportHandler.run(Editor.java:2028)
at java.lang.Thread.run(Thread.java:748)
Caused by: processing.app.SerialException: Error touching serial port 'COM5'.
at processing.app.Serial.touchForCDCReset(Serial.java:107)
at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:144)
... 5 more
Caused by: jssc.SerialPortException: Port name - COM5; Method name - openPort(); Exception type - Port busy.
at jssc.SerialPort.openPort(SerialPort.java:164)
at processing.app.Serial.touchForCDCReset(Serial.java:101)
... 6 more
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
Exception in thread "Thread-22" java.util.ConcurrentModificationException
at java.util.LinkedList$ListItr.checkForComodification(LinkedList.java:966)
at java.util.LinkedList$ListItr.next(LinkedList.java:888)
at processing.app.packages.LibraryList.getByName(LibraryList.java:61)
at cc.arduino.contributions.libraries.LibrariesIndexer.addToInstalledLibraries(LibrariesIndexer.java:130)
at cc.arduino.contributions.libraries.LibrariesIndexer.scanLibrary(LibrariesIndexer.java:229)
at cc.arduino.contributions.libraries.LibrariesIndexer.scanInstalledLibraries(LibrariesIndexer.java:201)
at cc.arduino.contributions.libraries.LibrariesIndexer.rescanLibraries(LibrariesIndexer.java:161)
at processing.app.BaseNoGui.onBoardOrPortChange(BaseNoGui.java:680)
at processing.app.Base.onBoardOrPortChange(Base.java:1313)
at processing.app.Editor$DefaultExportHandler.run(Editor.java:2058)
Last edited by adafruit_support_mike on Tue Oct 16, 2018 4:07 am, edited 1 time in total.
Reason: added CODE tags
- Clayface
sorry i hope this is what your asking for. also when i open IDE i get the message at the bottom "error downloading https://adafruit.github.io/arduino-boar ... index.json " before even trying to program anything *i also notice i do not have the metro m0 board as a drop down selection in my IDE
You posted the information I asked for, and it does show that you have the wrong board support package.
The error you're getting about the github.io URL is part of the larger problem. That file tells the Arduino IDE where to find our board support packages, and the process is failing at that step.
Try replacing the 'https' with 'http' and see if that works. Sometimes Github assumes secure connections come from someone with a Github account, so the system basically asks for a username and password. Plain HTTP queries just pull the data.
- Clayface
thank you very much for your help! im 3 steps closer,one step back. i get this error,and cant compile sketch.i used older ide as with the newer ones i cant find my board on the boards manager
Arduino: 1.6.4 (Windows 8.1), Board: "Adafruit Metro M0 Express"
arm-none-eabi-gcc: error: C:\Users\clayton\AppData\Local\Temp\build7122388264154794539.tmp/core.a: No such file or directory
Error compiling.
enabled in File > Preferences.
- Clayface
using latest ide. im struggling sorry
Arduino: 1.8.7 (Windows 8.1), Board: "Adafruit Metro M0 Express"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\clayton\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\clayton\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\clayton\Documents\Arduino\libraries -fqbn=adafruit:samd:adafruit_metro_m0 -ide-version=10807 -build-path C:\Users\clayton\AppData\Local\Temp\arduino_build_425142 -warnings=none -build-cache C:\Users\clayton\AppData\Local\Temp\arduino_cache_220280 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.bossac.path=C:\Users\clayton\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.8.0-48-gb176eee -prefs=runtime.tools.bossac-1.8.0-48-gb176eee.path=C:\Users\clayton\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.8.0-48-gb176eee -prefs=runtime.tools.openocd.path=C:\Users\clayton\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.9.0-arduino -prefs=runtime.tools.openocd-0.9.0-arduino.path=C:\Users\clayton\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.9.0-arduino -prefs=runtime.tools.CMSIS.path=C:\Users\clayton\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0 -prefs=runtime.tools.CMSIS-4.5.0.path=C:\Users\clayton\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\clayton\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1 -prefs=runtime.tools.arm-none-eabi-gcc-4.8.3-2014q1.path=C:\Users\clayton\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1 -prefs=runtime.tools.CMSIS-Atmel.path=C:\Users\clayton\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0 -prefs=runtime.tools.CMSIS-Atmel-1.2.0.path=C:\Users\clayton\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0 -verbose C:\Users\clayton\Documents\Arduino\libraries\Adafruit_DotStar\examples\strandtest\strandtest.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\clayton\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\clayton\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\clayton\Documents\Arduino\libraries -fqbn=adafruit:samd:adafruit_metro_m0 -ide-version=10807 -build-path C:\Users\clayton\AppData\Local\Temp\arduino_build_425142 -warnings=none -build-cache C:\Users\clayton\AppData\Local\Temp\arduino_cache_220280 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.bossac.path=C:\Users\clayton\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.8.0-48-gb176eee -prefs=runtime.tools.bossac-1.8.0-48-gb176eee.path=C:\Users\clayton\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.8.0-48-gb176eee -prefs=runtime.tools.openocd.path=C:\Users\clayton\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.9.0-arduino -prefs=runtime.tools.openocd-0.9.0-arduino.path=C:\Users\clayton\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.9.0-arduino -prefs=runtime.tools.CMSIS.path=C:\Users\clayton\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0 -prefs=runtime.tools.CMSIS-4.5.0.path=C:\Users\clayton\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\clayton\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1 -prefs=runtime.tools.arm-none-eabi-gcc-4.8.3-2014q1.path=C:\Users\clayton\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1 -prefs=runtime.tools.CMSIS-Atmel.path=C:\Users\clayton\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0 -prefs=runtime.tools.CMSIS-Atmel-1.2.0.path=C:\Users\clayton\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0 -verbose C:\Users\clayton\Documents\Arduino\libraries\Adafruit_DotStar\examples\strandtest\strandtest.ino
Using board 'adafruit_metro_m0' from platform in folder: C:\Users\clayton\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.2.3
Using core 'arduino' from platform in folder: C:\Users\clayton\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.2.3
"C:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10807 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD -D__SAMD21G18A__ -DARDUINO_SAMD_ZERO -DARM_MATH_CM0PLUS -DADAFRUIT_METRO_M0_EXPRESS -DUSB_VID=0x239A -DUSB_PID=0x8013 -DUSBCON "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Metro M0 Express\"" "-IC:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.2.3\\cores\\arduino" "-IC:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.2.3\\variants\\metro_m0" "C:\\Users\\clayton\\AppData\\Local\\Temp\\arduino_build_425142\\sketch\\strandtest.ino.cpp" -o nul
"C:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10807 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD -D__SAMD21G18A__ -DARDUINO_SAMD_ZERO -DARM_MATH_CM0PLUS -DADAFRUIT_METRO_M0_EXPRESS -DUSB_VID=0x239A -DUSB_PID=0x8013 -DUSBCON "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Metro M0 Express\"" "-IC:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.2.3\\cores\\arduino" "-IC:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.2.3\\variants\\metro_m0" "-IC:\\Users\\clayton\\Documents\\Arduino\\libraries\\Adafruit_DotStar" "C:\\Users\\clayton\\AppData\\Local\\Temp\\arduino_build_425142\\sketch\\strandtest.ino.cpp" -o nul
"C:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10807 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD -D__SAMD21G18A__ -DARDUINO_SAMD_ZERO -DARM_MATH_CM0PLUS -DADAFRUIT_METRO_M0_EXPRESS -DUSB_VID=0x239A -DUSB_PID=0x8013 -DUSBCON "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Metro M0 Express\"" "-IC:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.2.3\\cores\\arduino" "-IC:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.2.3\\variants\\metro_m0" "-IC:\\Users\\clayton\\Documents\\Arduino\\libraries\\Adafruit_DotStar" "-IC:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.2.3\\libraries\\SPI" "C:\\Users\\clayton\\AppData\\Local\\Temp\\arduino_build_425142\\sketch\\strandtest.ino.cpp" -o nul
Using cached library dependencies for file: C:\Users\clayton\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.2.3\libraries\SPI\SPI.cpp
"C:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10807 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD -D__SAMD21G18A__ -DARDUINO_SAMD_ZERO -DARM_MATH_CM0PLUS -DADAFRUIT_METRO_M0_EXPRESS -DUSB_VID=0x239A -DUSB_PID=0x8013 -DUSBCON "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Metro M0 Express\"" "-IC:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.2.3\\cores\\arduino" "-IC:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.2.3\\variants\\metro_m0" "-IC:\\Users\\clayton\\Documents\\Arduino\\libraries\\Adafruit_DotStar" "-IC:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.2.3\\libraries\\SPI" "C:\\Users\\clayton\\AppData\\Local\\Temp\\arduino_build_425142\\sketch\\strandtest.ino.cpp" -o "C:\\Users\\clayton\\AppData\\Local\\Temp\\arduino_build_425142\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\clayton\\AppData\\Local\\Temp\\arduino_build_425142\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10807 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD -D__SAMD21G18A__ -DARDUINO_SAMD_ZERO -DARM_MATH_CM0PLUS -DADAFRUIT_METRO_M0_EXPRESS -DUSB_VID=0x239A -DUSB_PID=0x8013 -DUSBCON "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Metro M0 Express\"" "-IC:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.2.3\\cores\\arduino" "-IC:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.2.3\\variants\\metro_m0" "-IC:\\Users\\clayton\\Documents\\Arduino\\libraries\\Adafruit_DotStar" "-IC:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.2.3\\libraries\\SPI" "C:\\Users\\clayton\\AppData\\Local\\Temp\\arduino_build_425142\\sketch\\strandtest.ino.cpp" -o "C:\\Users\\clayton\\AppData\\Local\\Temp\\arduino_build_425142\\sketch\\strandtest.ino.cpp.o"
Using previously compiled file: C:\Users\clayton\AppData\Local\Temp\arduino_build_425142\libraries\Adafruit_DotStar\Adafruit_DotStar.cpp.o
Using previously compiled file: C:\Users\clayton\AppData\Local\Temp\arduino_build_425142\libraries\SPI\SPI.cpp.o
Compiling core...
Using previously compiled file: C:\Users\clayton\AppData\Local\Temp\arduino_build_425142\core\variant.cpp.o
Using precompiled core: C:\Users\clayton\AppData\Local\Temp\arduino_cache_220280\core\core_adafruit_samd_adafruit_metro_m0_aaa3b01303e3b21a5af3a741eef1724a.a
"C:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-gcc" "-LC:\\Users\\clayton\\AppData\\Local\\Temp\\arduino_build_425142" -Os -Wl,--gc-sections -save-temps "-TC:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.2.3\\variants\\metro_m0/linker_scripts/gcc/flash_with_bootloader.ld" "-Wl,-Map,C:\\Users\\clayton\\AppData\\Local\\Temp\\arduino_build_425142/strandtest.ino.map" --specs=nano.specs --specs=nosys.specs -mcpu=cortex-m0plus -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -o "C:\\Users\\clayton\\AppData\\Local\\Temp\\arduino_build_425142/strandtest.ino.elf" "C:\\Users\\clayton\\AppData\\Local\\Temp\\arduino_build_425142\\sketch\\strandtest.ino.cpp.o" "C:\\Users\\clayton\\AppData\\Local\\Temp\\arduino_build_425142\\libraries\\Adafruit_DotStar\\Adafruit_DotStar.cpp.o" "C:\\Users\\clayton\\AppData\\Local\\Temp\\arduino_build_425142\\libraries\\SPI\\SPI.cpp.o" "C:\\Users\\clayton\\AppData\\Local\\Temp\\arduino_build_425142\\core\\variant.cpp.o" -Wl,--start-group "-LC:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Lib/GCC/" -larm_cortexM0l_math "-LC:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.2.3\\variants\\metro_m0" -lm "C:\\Users\\clayton\\AppData\\Local\\Temp\\arduino_build_425142/..\\arduino_cache_220280\\core\\core_adafruit_samd_adafruit_metro_m0_aaa3b01303e3b21a5af3a741eef1724a.a" -Wl,--end-group
"C:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-objcopy" -O binary "C:\\Users\\clayton\\AppData\\Local\\Temp\\arduino_build_425142/strandtest.ino.elf" "C:\\Users\\clayton\\AppData\\Local\\Temp\\arduino_build_425142/strandtest.ino.bin"
Using library SPI at version 1.0 in folder: C:\Users\clayton\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.2.3\libraries\SPI
"C:\\Users\\clayton\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-size" -A "C:\\Users\\clayton\\AppData\\Local\\Temp\\arduino_build_425142/strandtest.ino.elf"
Sketch uses 12152 bytes (4%) of program storage space. Maximum is 262144 bytes.
Forcing reset using 1200bps open/close on port COM3
PORTS {COM3, } / {COM3, } => {}
Uploading using selected port: COM3
C:\Users\clayton\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.7.0/bossac -i -d --port=COM3 -U true -i -e -w -v C:\Users\clayton\AppData\Local\Temp\arduino_build_425142/strandtest.ino.bin -R
Set binary mode
No device found on COM3
readWord(addr=0)=0x30455553
readWord(addr=0xe000ed00)=0x2c303437
readWord(addr=0x400e0740)=0x53002334
version()=BSU00000,4#
chipId=0x53002334
Unsupported processor
Send auto-baud
Set binary mode
readWord(addr=0)=0x342c3034
readWord(addr=0xe000ed00)=0x42530023
readWord(addr=0x400e0740)=0x30455553
version()=740,4#
chipId=0x30455553
Unsupported ARM7TDMI architecture
An error occurred while uploading the sketch
- Clayface
I got it!! I scoured the forums for any key words or anything. I ended up uninstalling all drivers for board and restarting-it worked! Thank you again,your even in prince george ill buy you a timmies
Glad to hear you got it working. IDE problems can be a pain in the neck.
Happy hacking!
Happy hacking!
