[SOLVED] Adding additional serial using SERCOM causes hang
by btechnet on Thu May 30, 2019 2:15 pm
Using a Metro M4
And I need an additional serial port.
I setup SERCOM 5 to pins D2 and D3
Uart Serial5(&sercom5, 2, 3, SERCOM_RX_PAD_1, UART_TX_PAD_0);
void SERCOM5_Handler()
  Serial5.IrqHandler();
void setup()
    pinPeripheral(2, PIO_SERCOM);
    pinPeripheral(3, PIO_SERCOM);
    Serial5.begin(9600)
void loop(){
 Serial5.println("running");
 delay(1000);
After hooking up a ftdi to those pins i get the first 2 letters "ru" and then the loop code execution stops.
Debugging going into a Dummy_Handler in cortex_handlers.c
I have tried this same code on arduino and vscode platformio with the same results.
I have also tried SERCOM 4 with the same results.
What am I missing here?
Adafruit datasheet for metro m4:
https://cdn-learn.adafruit.com/assets/assets/000/053/093/original/adafruit_products_schem.png?1524085993
Code example taken from Adafruit website:
https://learn.adafruit.com/using-atsamd21-sercom-to-add-more-spi-i2c-serial-ports/creating-a-new-serial
-Anthony
btechnet
Re: Adding additional serial using SERCOM causes hang when p
by btechnet on Thu May 30, 2019 2:27 pm
It appears the code example from here are not totally accurate:
There are multiple handlers for SERCOM's not just one.
The solution was to declare the handlers properly:
void SERCOM5_0_Handler()
void SERCOM5_1_Handler()
void SERCOM5_2_Handler()
void SERCOM5_3_Handler()
btechnet
Re: [SOLVED] Adding additional serial using SERCOM causes ha
by Ddahl08 on Fri Jun 14, 2019 5:40 pm
I am having the same issue although adding multipule Handler() did not seem to do anyting different. Any other solutions out there?
Ddahl08
