Can't upload to Metro - "Programmer Not Responding"
by tardistrekkie on Thu Apr 22, 2021 10:47 pm
Hi there,
I'm having trouble sending information to my Metro and was hoping y'all could advise.
First note - the power light comes on when I plug it in, but if I hit the "Reset" button there's no response. I saw in the tutorial that the "L" light should blink when the button is hit but that's not the case for me. Does that mean that the bootloader is corrupted?
I made sure to install the latest drivers (v2.5.0.0) and updated the board libraries in the Arduino IDE
Here's what my Device Manager looks like:
I tried just uploading the generic "Blink" Sketch and got this response:
Arduino: 1.8.13 (Windows 10), Board: "Arduino/Genuino Uno"
Sketch uses 924 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x37
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x37
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x37
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x37
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x37
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x37
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x37
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x37
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x37
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x37
Not sure if there's anything I can do at this point or if I have a bad board. Thanks for your time!
tardistrekkie
Re: Can't upload to Metro - "Programmer Not Responding"
by dastels on Thu Apr 22, 2021 11:18 pm
Have you tried resetting (or double resetting) while it's searching for the board?
You you have a serial connection to the board?
dastels
by tardistrekkie on Fri Apr 23, 2021 5:08 pm
Just tried doing both the single and double reset while it was searching, unfortunately nothing seemed to react on the board.
I did pull up the serial monitor, but nothing populates in the window while I'm running it.
tardistrekkie
by dastels on Fri Apr 23, 2021 5:31 pm
Try selecting "Adafruit Metro" as the board.
dastels
