Hardware suggestions please
by AlexJustAlex on Mon Sep 27, 2021 9:38 am
I have an upcoming project where I have to capture data from 2 rs232 devices, temporarily (for a month or so and can then be overwritten) save that data (probably to an sd card) and then output that same data on 2 more rs232 ports.
So I need 4 rs232 ports, a suitable microprocessor board and a suitable storage solution.
I have previously played successfully with a Metro M4 Express AirLift, so I'm considering another of these, but all suggestions welcome. If the hardware can be sourced within the UK that would be a bonus.
cheers
Alex
AlexJustAlex
Re: Hardware suggestions please
by Jeremy97469 on Mon Oct 11, 2021 6:21 am
Have you considered the Grand Central M4? It comes with the Micro SD card slot already there. It also has 8 serial ports (SERCOM).
Jeremy97469
by adafruit_support_bill on Mon Oct 11, 2021 7:50 am
The M4 suggested above would be a good choice .
Note that the serial ports on microcontrollers in general are TTL serial. RS232 uses inverted logic and a higher signal voltage. To communicate with RS232 serial devices you will need an RS232 to TTL converter. SeeedStudio makes a nice one:
https://www.seeedstudio.com/RS-232-To-T ... -2851.html
by nbaever3 on Wed Oct 13, 2021 2:36 pm
Jeremy97469 wrote:Have you considered the Grand Central M4? It comes with the Micro SD card slot already there. It also has 8 serial ports (SERCOM).
I have also the same question that did you considered M4?
nbaever3
cron
