Pygamer
Pygamer
by craigcooper on Mon Oct 11, 2021 4:28 pm
My pygamer works seldom and when it does, the screen display is faint. I went on Youtube last night and saw what the display is supposed to look like. Mine has never looked like that. I have ordered a new one, but would like a replacement for the one I have as well.
- Craig
craigcooper
Re: Pygamer
by adafruit_support_carter on Mon Oct 11, 2021 6:03 pm
Is the board otherwise running OK?
Can you post some photos so we can look for anything obviously wrong with the hardware.
Re: Pygamer
by craigcooper on Mon Oct 11, 2021 7:05 pm
"is the Pygamer running well aside from that?"
I can not see the screen. How would I know.
Charging my phone and will send photos when available.
craigcooper
Re: Pygamer
by craigcooper on Mon Oct 11, 2021 8:02 pm
Here are a few photos.
All green neopixels after a double reset
dim green on the left and four bright white on the right when pressing reset once after it has been double pressed
- craigcooper
craigcooper
Re: Pygamer
by adafruit_support_carter on Tue Oct 12, 2021 11:18 am
This sounds correct and good. Are you also seeing the PYGAMERBOOT folder showing up on your PC at the same time?
Re: Pygamer
by craigcooper on Tue Oct 12, 2021 5:08 pm
Yes, PYGAMERBOOT shows up
craigcooper
Re: Pygamer
by adafruit_support_carter on Tue Oct 12, 2021 6:33 pm
Cool. We can try a self test. Download the UF2 file linked from the green box at the top of this page:
https://learn.adafruit.com/adafruit-pyg ... shooting-2
Drag the UF2 file to the PYGAMERBOOT folder. It should reset once the copy is complete and run the example. Any change to the screen?
Re: Pygamer
by craigcooper on Tue Oct 12, 2021 9:07 pm
The screen remains dark.
craigcooper
Re: Pygamer
by adafruit_support_carter on Wed Oct 13, 2021 5:22 pm
Is this a new Pygamer? It's been like this out of the box?
Re: Pygamer
by craigcooper on Wed Oct 13, 2021 6:55 pm
It is new. It has been like this out of the box. I have been trying to get this to work, assuming it was a working product. From time to time, the display will come on, faint and only for a short time.
- Craig
craigcooper
Re: Pygamer
by adafruit_support_carter on Thu Oct 14, 2021 11:41 am
OK, let's just replace it. Not sure what's going on, seems like something marginal, but probably not something easily user fixable.
Send an email to support@adafruit.com with a link to this thread and your order number and they can send you a replacement PyGamer (PID 4242).
