Metro M4 Airlift Lite, TinyUSB Not Recognized by Win 10
by Exonerd on Tue Oct 12, 2021 10:31 pm
Greetings,
Using Arduino IDE with a Metro M4 Airlift Lite that had been working well previously, I switched the USB stack to "TinyUSB" as I wanted to experiment with the expanded capabilities. My generic sketch compiled and uploaded, but then the board disappeared from Windows and shows up with a "USB Device Unrecognized" error. Used the latest Adafruit driver package (2.5.0.0) and still can't get the board to show up properly. Is there an easy fix for this?
Exonerd
Re: Metro M4 Airlift Lite, TinyUSB Not Recognized by Win 10
by hathach on Thu Oct 14, 2021 6:27 am
it is probably caused by `while(!Serial) {}` (or similar), try to add an yield() or delay(1) to allow mcu to run the tinyusb background task e.g
while(!Serial) yield(); // or delay(1)
Otherwise, please post your minimal sketch here for analysis can
hathach
by Exonerd on Thu Oct 14, 2021 4:17 pm
Thanks but I can't even get the board to show up for reprogramming at this state. Should I burn a fresh bootloader to reset the board, or is there a fix in Windows?
Exonerd
by Exonerd on Sat Oct 16, 2021 6:27 pm
Resolved:
If you ever lose communication with the Arduino IDE and Windows due to a serial port error in your code, switching to bootloader mode (double-tap the reset button whilst connected to USB) will make the board reappear in Windows and the Arduino IDE, allowing for flashing a fresh sketch. I was worried I'd have to burn new bootloaders, etc. Thank you Adafruit for your handy capability to switch to CircuitPython!
Unresolved:
When switching to the TinyUSB stack, I get a compiler error for that delay command put in place to let the USB process complete, saying there is "unknown reference to Serial":
  while(!Serial){
    yield();
Exonerd
