Due to high demand expect some shipping delays at this time, orders may not ship for 3-4 business days. On MLK Day no orders will be shipped.
Metro Express - Either I or the Board is Terribly Inadequate
by HenryM on Mon Dec 06, 2021 8:04 pm
Edit: I'm using CircuitPython 7.0.0
My goal is to drive three 14-segment alphanumeric displays using a Metro Express M0 and, well, it just doesn't seem up to the challenge. Essentially, right now, I have a single neopixel (the one included on the board) and I'm trying to import the ht16k33 library. Here's my code:
main.py
import board
import neopixel
import digitalio
import busio
from adafruit_ht16k33 import segments
i2c = busio.I2C(board.SCL, board.SDA)
pixel = neopixel.NeoPixel(board.NEOPIXEL, 1)
pixel.brightness = 0.1
while True:
    pixel[0] = [255, 0, 0]
    time.sleep(0.1)
    pixel[0] = [0, 0, 0]
    time.sleep(0.9)
  File "main.py", line 7, in <module>
  File "adafruit_ht16k33/segments.py", line 392, in <module>
MemoryError: memory allocation failed, allocating 96 bytes
HenryM
Re: Metro Express - Either I or the Board is Terribly Inadeq
by mikeysklar on Mon Dec 06, 2021 10:00 pm
HenryM,
Can you try loading the MPY library files (pre-compiled) for segements / neopixel. You had been calling the PY file which is larger. Also please make sure you are running CircuitPython 7.x
https://github.com/adafruit/Adafruit_Ci ... 211202.zip
mikeysklar
by HenryM on Tue Dec 07, 2021 8:40 am
As far as I know, I have been using the precompiled binaries. Everything within `adafruit-circuitpython-bundle-7.x-mpy-20211202/lib` is precompiled? And I do confirm that I've been using CircuitPython 7.0.0.
HenryM
by mikeysklar on Tue Dec 07, 2021 4:47 pm
@HenryM,
I have both bundles of source and compiled files. Since your error in the REPL had the source file extension of *.py versus the compiled extension of *.mpy I think you might be using the source files. Can you check your CIRCUITPY/lib folder to confirm what the file extensions are on your libraries?
In terms of how to verify the version of CircuitPython running on your device take a lok at CIRCUITPY/boot_out.py. It should look something like this:
$ cat boot_out.txt
Adafruit CircuitPython 7.0.0 on 2021-09-20; Adafruit Feather RP2040 with rp2040
Board ID:adafruit_feather_rp2040
mikeysklar
by HenryM on Tue Dec 07, 2021 6:17 pm
Contents of boot_out.txt:
Adafruit CircuitPython 7.0.0 on 2021-09-20; Adafruit Metro M0 Express with samd21g18
Board ID:metro_m0_express
The files within the `lib` directory are almost all .mpy. The only exceptions are within the subdirectories, there are a few 0 length __init__.py files
HenryM
by HenryM on Tue Dec 07, 2021 8:36 pm
I sincerely appreciate your suggestions mikeysklar. So thank you for the help.
For what its worth, I'm just going to do this project in Arduino mode. I didn't even intend to get something that would run CircuitPython, it was just something that was in stock and looked like it could easily handle what I want. When I saw that it was set up for CircuitPython by default, I decided to roll with it. I'm now using in "regular" Arduino mode and I'm able to pound the code out very quickly.
HenryM
by danhalbert on Wed Dec 08, 2021 10:14 am
The backtrace will say (somewhat misleadingly) `.py` even if the file is `.mpy`.
danhalbert
