Program on Arduino not working on Metro Board
Bubby0626
Post by Bubby0626 »
So I have been able to execute the program on the Arduino Uno below. Basically what the program does is turn on these LEDs/motors (I've been using LEDs) in an on/off pattern while being able to be controlled by a potentiometer. When I tried it on the Metro, I have no trouble compiling it, but it doesn't work at all. Would someone know why this is happening?
Code:
#define LED_1_PIN 5
#define LED_2_PIN 6
#define LED_3_PIN 3
#define LED_4_PIN 9
#define LED_5_PIN 10
#define LED_6_PIN 11
const int potPin = A0;
int readValue = 0;
int writeValue;
int brightness = 0;
int motorState = 0;
int inputVal = 0;
void setup()
  Serial.begin(9600);
  pinMode(potPin, INPUT);
  pinMode(LED_1_PIN, OUTPUT);
  pinMode(LED_2_PIN, OUTPUT);
  pinMode(LED_3_PIN, OUTPUT);
  pinMode(LED_4_PIN, OUTPUT);
  pinMode(LED_5_PIN, OUTPUT);
  pinMode(LED_6_PIN, OUTPUT);
void Potentiometer()
  readValue = analogRead(potPin);
  brightness = (255./1023.) * readValue;
  if (readValue > 0)
    vibrate();
void vibrate()
  if(motorState == 0) {
    analogWrite(LED_1_PIN, brightness);
    analogWrite(LED_2_PIN, brightness);
    analogWrite(LED_3_PIN, brightness);
    analogWrite(LED_4_PIN, 0);
    analogWrite(LED_5_PIN, 0);
    analogWrite(LED_6_PIN, 0);
    motorState = motorState + 1;
  else if(motorState == 1)
    analogWrite(LED_1_PIN, 0);
    analogWrite(LED_2_PIN, 0);
    analogWrite(LED_3_PIN, 0);
    analogWrite(LED_4_PIN, brightness);
    analogWrite(LED_5_PIN, brightness);
    analogWrite(LED_6_PIN, brightness);
    motorState = 0;
void loop()
  static unsigned long previousMillis = 0;
  if (millis() - previousMillis >= 500)
    previousMillis += 500;
   Potentiometer();
dastels
Re: Program on Arduino not working on Metro Board
Post by dastels »
Is your board setting correct?
mikeysklar
Post by mikeysklar »
Which model of the Adafruit Metro are you using?
RogierWeekers
Post by RogierWeekers »
Maybe your calculation is wrong.
analogRead gives a 12 bit (max 4095) value, and i would cast readValue to float before calculation to make sure it is not treated as an integer.
brightness = (255.0/4096.0) * (float) readvalue
dastels
Post by dastels »
Good catch. The '328 has 10-bit ADCs. If you have a SAMD based Metro, the ADCs are 12 bit.
mikeysklar
SAMD Metros would also be 3v3 based so possibly some wiring changes are needed. Still don't know which model of Metro is being used here.
Return to “Metro, Metro Express, and Grand Central Boards”
