Memory types and uses
by PierreDeQuebec on Mon May 16, 2022 9:00 am
For the Metro M4 Express Airlift Lite microcontroler:
512 KB flash
192 KB RAM
2 MB QSPI flash
In the document "Adafruit Metro M4 Express AirLift (WiFi)", it is written:
When used in Circuit Python, the 2 MB flash acts as storage for all your scripts, libraries and files.
and
In CircuitPython, the QSPI flash is used natively by the interpretter and is read-only to user code, instead the Flash just shows up as the writeable disk drive!
So, I deduce that CircuitPython does not use QSPI flash memory for my dynamic variables (those created by running my code). Currently, my program crashes due to lack of RAM memory. And this, despite having "frozen" several Adafruit modules and some of my project (there are only 112 B left in the Flash memory). I deduce that the RAM memory is used for my dynamic variables and no doubt that my problem of lack of memory comes from there. Yet I only use 0.39 MB of the 2 MB QSPI Flash. Is it possible to use QSPI Flasg memory for dynamic variables in my programs?
PierreDeQuebec
Re: Memory types and uses
by User_UMjT7KxnxP8YN8 on Mon May 16, 2022 10:44 am
No, it is not possible to use QSPI flash memory for variables. Flash memory must be erased before its contents can be changed, and it is not possible to erase individual memory locations; instead, you would have to save the contents of the page containing the location you want to change, erase the entire page (256 bytes), then rewrite the entire page including the location(s) you wanted to modify. You can do this about 100,000 times before the flash memory no longer works properly.
Instead, focus on reducing your dynamic variable use. Declare variables (especially strings) that don't change as "const", make arrays no larger than they absolutely have to be, pass variables to functions by reference (i.e., by address) rather than by value for a start. You may have to rewrite code to recover RAM; it's usually possible to trade CPU cycles for RAM. For instance, rather than copying data into another buffer at the expense of doubling RAM use, devise a way to work with the data in-place.
User_UMjT7KxnxP8YN8
by PierreDeQuebec on Mon May 16, 2022 11:07 am
Thanks for your advices. I will follow them.
PierreDeQuebec
