Metro M4 Express Beta
Post Reply
GrmpyMan
Post by GrmpyMan »
I just started to try and use an older Metro M4 Express Beta but can't find the info anymore on my PC, Adafruit nor anywhere else.
If someone can provide it that would be wonderful!
dastels
Re: Metro M4 Express Beta
Post by dastels »
GrmpyMan
Post by GrmpyMan »
Dave,
I remember a different procedure to get it to work. Are you saying that it now follows the same as a regular Metro M4?
The one I have is in black so I thought that it would be different since I remember having to install a boot loader on the board.
This looks quite different from the ones shown on the Adafruit site
dastels
Post by dastels »
I'm saying that guide should apply. It's a Metro M4 Express. There are occasionally some cosmetic differences (like a different colour solder mask) between batches. Boards usually come with a bootloader installed. I do recall that the early Metro M4 Express "Beta" didn't.
GrmpyMan
Post by GrmpyMan »
Sorry but nothing works with this variety of Metro M4 Express. You'd need to contact Lady Ada about how to get this particular board to work.
If that can't be done I guess I'll just toss it.
dastels
Post by dastels »
Have you had it working in the past?
westfw
Post by westfw »
FWIW, I also have a black-soldermask "Metro M4" with BETA on the back, and it still works fine (set as "Metro m4" in the Boards menu, from a Mac running Arduino IDE 1.8.13) (and it also shows up as the USB disk...)
dastels
Post by dastels »
You didn't answer my question.
Anyway. Does it enter bootloader mode if you double press reset?
adafruit2
Post by adafruit2 »
all metro m4, even 'beta' have working bootloaders. doubleclicking the reset button should launch the bootloader manually and the neopixel will light up green (USB OK) or red (USB failure)
Post Reply
Return to “Metro and Metro Express, Grand Central”
