I'm trying to port a project from an UNO to the Metro M0 Express. The project uses a 20X4 LCD module working via I2C. It works fine with the UNO. When compiling for the M0, I get a warning that the LiquidCrystal_I2C library is not compatible. The project compiles OK and uploads, but the LCD doesn't work. I've also tried the adafruit_liquidcrystal library and the HelloWorldI2C example file, but that doesn't work either. I've also tried adding a logic shifter to the scl and sda pins connected via A5 and A4.
Any thoughts on getting the LCD to work with the Metro M0 board? Is there a different library I should be using?
Using Metro M0 with I2C LCD
Re: Using Metro M0 with I2C LCD
Try using one of these libraries instead:
https://github.com/adafruit/Adafruit-RG ... ld-Library
https://github.com/adafruit/Adafruit_LiquidCrystal
- steve220
Thanks. I got the LCD working fine with the liquidcrystal_I2C library. Pins A4 and A5 wouldn't work, but the hardware I2C pins worked after using a level shifter. I still get a compiler warning, but everything works fine.
What warning are you getting?
- steve220
WARNING: library LiquidCrystal_I2C claims to run on (avr) architecture(s) and may be incompatible with your current board which runs on (samd) architecture(s).
Sketch uses 32004 bytes (12%) of program storage space. Maximum is 262144 bytes.
Ah, that's the Arduino IDE being 'helpful'. As long as the code works it's safe to ignore the warning.
