Is there a premade footprint library for Eagle for the Metro Mini? or is my best bet to pull the board dimensions from the original design files?
Thank you!
Metro Mini Eagle Library
Re: Metro Mini Eagle Library
If you want to make your own board that connects to the Metro Mini, it's easiest to use a couple rows of 0.1" header spaced 0.6" apart. Those will give you the connection points you need, and you can label the signals any way you want.
- jps2000
You can always extract the library from eagle brd and sch files
copy those files from github in a project folder and open the design
Then you go to file/export / libraries and thats it.
