cannot connect to Adafruit METRO 328
by hliang on Thu Jan 17, 2019 8:17 pm
The "port" field is grayed out. I go to device manager(Windows 7) and there is nothing under "Ports".
I already installed the CP2014 VCP drivers.
Thanks for the help!
hliang
Re: cannot connect to Adafruit METRO 328
by franklin97355 on Thu Jan 17, 2019 10:39 pm
When you plug in the Metro does the computer see a USB connection (plays a tone)? If not you might want to verify the cable you are using has data capability. Some cables are charging only.
franklin97355
by hliang on Fri Jan 18, 2019 2:28 pm
Yes, that's the problem. I changed the cable and it connects.
Thank you!
hliang
