Powering Metro Mini 328 From Battery
by LimeAY on Tue Jan 29, 2019 2:08 pm
As the title says, I need to power the Metro Mini Microcontroller from a 5V battery.
How would i go about doing this?
Do i need to use a voltage regulator or does this controller have on built in if i were to use a 9V battery?
If so is there some form of adapter to allow me to power it with this battery type, i.e 9V battery to Micro Usb?
Any help would be great thanks!
LimeAY
Re: Powering Metro Mini 328 From Battery
by adafruit_support_bill on Tue Jan 29, 2019 2:18 pm
If you have a regulated 5v source, you can feed it directly to the 5v pin on the Metro - or via the USB jack.
If you have a higher voltage source (e.g. a 9v battery), connect it to the VIN pin. There is an on-board 5v regulator.
The VIN pin can handle from 6v-16v. Lower is better since higher supply voltages will cause the regulator to get quite warm.
