Grand Central M4 - Arduino upload "SAM-BA operation failed"
by Blurfl on Sun Feb 10, 2019 2:51 am
I've been unable to upload a simple Blink sketch to either of two Grand Central M4 units on hand. Both units work as expected with CircuitPython and with MakeCode. Both fail to upload in the Arduino 1.8.8 IDE, on macOS and Win10. The upload error message output from the macOS Arduino IDE is attached.
It may be something I've overlooked, can someone help me spot what it is?
Arduino_upload_error_output.txt
(13.67 KiB) Downloaded 5 times
Blurfl
Re: Grand Central M4 - Arduino upload "SAM-BA operation fail
by Blurfl on Sun Feb 10, 2019 7:56 pm
I've been exploring the issue looking for more information, and I've found a work-around. After removing the '-e' erase parameter from the tools.bossac18.upload.pattern in '...Arduino15/packages/adafruit/hardware/samd/1.2.9/platform.txt' the upload runs as expected.
I tried that after seeing that bossac v1.8 has a comment on the -w option "write FILE to the flash; accelerated when combined with erase option " .
To sum up, the standard line fails as described earlier:
tools.bossac18.upload.pattern="{path}/{cmd}" {upload.verbose} --port={serial.port.file} -U -i --offset={upload.offset} -e -w -v "{build.path}/{build.project_name}.bin" -R
but removing the '-e' works:
tools.bossac18.upload.pattern="{path}/{cmd}" {upload.verbose} --port={serial.port.file} -U -i --offset={upload.offset} -w -v "{build.path}/{build.project_name}.bin" -R
Not sure why this works, but I hope it might help point to the solution.
Blurfl
by adafruit_support_mike on Mon Feb 11, 2019 5:06 am
Thank you for posting the information.
The Arduino IDE sometimes picks up bugs when a new version is released. When in doubt, try dropping back to an older version of the IDE and see if that solves the problem.
by Blurfl on Mon Feb 11, 2019 5:59 pm
Dropping back to Arduino 1.8.7 made no difference.
I think the issue is has something to do with the bossac tool. From the command line, version 1.8.0-48-gb176eee that comes with the Arduino IDE and the current release version 1.9.1 both fail for a 'write after erase' and work as expected for a write without the erase. Earlier versions of the tool don't support the --offset parameter, so I haven't tried those...
I've been using 'AdaFruit SAMD Boards' version 1.2.9, as earlier versions don't support the Grand Central.
Looking at the ArduinoCore-samd repository, there is a recent commit to the master branch eliminates the '-e' erase option from the bossac command string for a performance improvement:
https://github.com/adafruit/ArduinoCore ... 6e147daa53
From that, it looks like my issue will go away with the next 'AdaFruit SAMD Boards' release, so I'll use the development master until then.
Blurfl
