GrandCentral Shorted Pins
by sandoralex on Tue Feb 12, 2019 7:34 pm
I orderd two Grandcentral M4 Express boards, and one appears to have a solder bridge across two of the pins. The order # is 1969928-5297158272.
I have uploaded a picture showing the problem. The board on the right has the pins near the silkscreen in the area of the letter 'e' in Atmel.
I have not powered on the board as I am not comfortable doing so with the pins shorted.
Photo showing the shorted pins.
Please advise.
Thank you, Alex
sandoralex
Re: GrandCentral Shorted Pins
by adafruit_support_bill on Wed Feb 13, 2019 6:57 am
Looks like pins 108 and 109 on the TQFP. pin 108 is connected to the on-board Neopixel. Pin 109 is unused. Go ahead and power it up & verify that the neopixel is working.
by sandoralex on Wed Feb 13, 2019 1:30 pm
Hi Bill,
I uploaded the neopixel test sketch, and the neopixel seems to be operating fine, so I will accept the board as is.
Hopefully there are no other issues with soldering on the board. Time will tell.
Upon closer examination of the board using my USB microscope, I noticed that the Atmel chip has solder flux left on the pins. Should I clean it off?
Thank you,
Alex
sandoralex
by adafruit_support_bill on Wed Feb 13, 2019 1:58 pm
That is what I would expect. We do test every board as they come off the reflow line, so most harmful soldering issues would be detected at that time.
We use a "no clean" flux which does leave a small amount of harmless residue. You can clean it if desired, but it is not necessary.
by sandoralex on Wed Feb 13, 2019 2:18 pm
Thank you for your help Bill!
Alex
sandoralex
