Grand Centeral How to use Port Registers?
by DropBear on Wed Jun 12, 2019 1:18 pm
I'm missing soemthing here.
I'm using the Arduino IDE with a Grand Central and trying to use Port Registers.
I have the SAMD and Adafruit SAMD board libraries loaded and have been able to do a few simple blink tests with individual pins.
I can see PORTA, PORTB, PORTC, PORTD, and PinDescription being defined in ibrary file variant.cpp located in ~/Library/Arduino15/packages/adafruit/hardware/samd/1.5.0/variants/grand_central_m4.
Modifying the simple blink test I have:
  // Set all PORTC as output
  DDRC = 0xFF;
  PORTC = 0xFF;  // Set all digital PORTC pins on
  delay(1000);
  PORTC = 0x00;  // Set all digital PORTC pins off
  delay(1000);
But I'm getting the error:
 port101.ino: In function 'void setup()':
port101:3:3: error: 'DDRC' was not declared in this scope
   DDRC = 0xFF;
port101.ino: In function 'void loop()':
port101:8:9: error: lvalue required as left operand of assignment
port101:11:9: error: lvalue required as left operand of assignment
exit status 1
Should I be including another file or do I need to define the registers myself?
I'm not sure how variant.cpp comes into play with the Arduino IDE.
DropBear
Re: Grand Centeral How to use Port Registers?
by adafruit_support_carter on Wed Jun 12, 2019 2:26 pm
The SAMD on the Grand Central is an ARM based processor, not AVR. You're trying to do low level AVR stuff.
by DropBear on Wed Jun 12, 2019 3:25 pm
Is there a way to simply set/read a group of digital pins without a loop then?
I would hope the advertised "Parallel Capture Peripheral" with 14 Digital Pins aren't being polled individually?
The grouping of PORTA through PORTD on the schematic and in the variant.cpp seems to hint at it still.
Did find this post that also shows using PORTA with a different syntax:
https://forums.adafruit.com/viewtopic.php?f=63&t=148693&p=739206&hilit=PORTA#p739206
DropBear
by adafruit_support_carter on Wed Jun 12, 2019 4:12 pm
You may be able to, but you would need to consult the datasheet for the SAMD chip and probably the API documentation for the support library from Atmel.
by westfw on Fri Jun 14, 2019 11:18 pm
There’s an example here: viewtopic.php?f=57&t=133497#p668379
The samd chips are much different than the avrs.
westfw
by DropBear on Tue Jun 18, 2019 1:13 pm
Thanks for the hints.
The examples still point to single pin direct access but still digging into it.
Experimenting with the pin mask to see if multiple pins can be set.
I see the PCC camera definition in the SAMD51 port.h and looking at how that is used as an example.
DropBear
