Having Trouble Finding Interrupt Resources
by MatthewMenze on Thu Jan 30, 2020 3:01 pm
I have been searching around for examples/guides of setting up a timer based interrupt with the Metro M4 Airlift, I was wondering if you could point me towards some resources?
I did find a SAMD51 Interrupt Library: https://github.com/Dennis-van-Gils/SAMD ... rruptTimer
But I had little luck implementing it on the board, I couldn't seem to get the interrupt to trigger. I was hoping to find something that worked with Arduino's interrupt handlers, as they work pretty slick for setting up simple timer interrupts on other boards, and blocking interrupts on specific code is quick and easy.
Currently I am using periodic checks to millis to run a periodic update function, but it's not a true interrupt so I am running into some limitations.
Any reference material you know about would be hugely appreciated!
Thank you!
Matt
MatthewMenze
Re: Having Trouble Finding Interrupt Resources
by adafruit_support_mike on Fri Jan 31, 2020 5:47 am
I'm afraid we haven't done any work with timer-based interrupts on the SAMD51. Maybe someone from the community will have more information.
by westfw on Fri Jan 31, 2020 6:13 am
What kind of time intervals and behavior are you looking for?
"Normally", timer libraries can conflict with the Arduino built-in uses of the timers (ie for PWM.)
I think the RTC module of the SAMD51 chips is currently unused, but it's limited to a 32kHz clock
westfw
by User_UMjT7KxnxP8YN8 on Sat Feb 01, 2020 7:04 pm
I wrote code for the SAMD51x that implements real-time clock interrupts. Not exactly what you're looking for but you might glean helpful information from it.
https://github.com/SapientHetero/Real-time-Clock-for-ATSAMD51
User_UMjT7KxnxP8YN8
by stratosfear on Sun Feb 02, 2020 7:55 am
I think what I've got below will work for you. I chose to use a TC peripheral and save the more flexible TCC counters for possible future use. Note that D13 will toggle every interrupt, thus appearing to give you a 0.5Hz clock.
    Adafruit Grand Central M4 Only: 1Hz timer for flight timer
static volatile bool toggle = 0;
#define togglePin 13
void setup()  {
  // Set up the generic clock (GCLK7) to clock timer TC6
  GCLK->GENCTRL[7].reg = GCLK_GENCTRL_DIV(3) |        // Divide the 48MHz clock source by divisor 3: 48MHz/3 = 16MHz
                         GCLK_GENCTRL_IDC |           // Set the duty cycle to 50/50 HIGH/LOW
                         GCLK_GENCTRL_GENEN |         // Enable GCLK7
                         GCLK_GENCTRL_SRC_DFLL;       // Select 48MHz DFLL clock source
                         //GCLK_GENCTRL_SRC_DPLL0;    // Select 100MHz DPLL clock source
                         //GCLK_GENCTRL_SRC_DPLL0;    // Select 120MHz DPLL clock source
  while (GCLK->SYNCBUSY.bit.GENCTRL7);                // Wait for synchronization
  GCLK->PCHCTRL[TC6_GCLK_ID].reg = GCLK_PCHCTRL_CHEN |       // Enable the TC6 peripheral channel
                                   GCLK_PCHCTRL_GEN_GCLK7;   // Connect generic clock 7 to TC6
  TC6->COUNT16.CTRLA.bit.ENABLE = 0;                         // Disable timer TC6
  while (TC6->COUNT16.SYNCBUSY.bit.ENABLE);                  // Wait for synchronization
  TC6->COUNT16.CTRLA.reg = TC_CTRLA_PRESCALER_DIV1024 |       // Set prescaler to 4, 16MHz/1024 = 15.625KHz
                           TC_CTRLA_PRESCSYNC_PRESC |         // Set the reset/reload to trigger on prescaler clock
                           TC_CTRLA_MODE_COUNT16;
  TC6->COUNT16.WAVE.reg |= TC_WAVE_WAVEGEN_MFRQ;             // Use MFRQ so TOP can be set by CC[0] in COUNT16 mode
  TC6->COUNT16.CC[0].reg = 0x3d08;                           // Sets ~1Hz
  while (TC6->COUNT16.SYNCBUSY.bit.CC0);                     // Wait for synchronization
  TC6->COUNT16.INTENSET.bit.MC0 = 1;                         // enable interrupt on COMPARE0
  TC6->COUNT16.CTRLA.bit.ENABLE = 1;                         // Enable timer TC6
  NVIC_SetPriority(TC6_IRQn, 0);
  NVIC_EnableIRQ(TC6_IRQn);
  pinMode(togglePin, OUTPUT);
void loop()  {
void TC6_Handler() {
  TC6->COUNT16.INTFLAG.bit.MC0 = 1;                         // IMPORTANT! reset interrupt flag!
  toggle = !toggle;
  digitalWrite(togglePin, toggle);
  //increment flight timer here
I also needed a one-shot timer to erase alerts on a TFT screen. In this example a momentary switch simulates the print routine and retriggers the timer.
   Adafruit Grand Central M4 Only: Set-up 2 second timer to erase screen alerts
void setup()  {
  pinMode(2, INPUT_PULLUP);
  attachInterrupt(2, swISR, FALLING);
  // Set up the generic clock (GCLK7) to clock timer TC3
  GCLK->PCHCTRL[TC3_GCLK_ID].reg = GCLK_PCHCTRL_CHEN |       // Enable the TC3 peripheral channel
                                   GCLK_PCHCTRL_GEN_GCLK7;   // Connect generic clock 7 to TC3
  TC3->COUNT16.CTRLA.reg = TC_CTRLA_PRESCALER_DIV1024 |      // Set prescaler to 1024, 16MHz/1024 = 15.625KHz
  TC3->COUNT16.WAVE.reg |= TC_WAVE_WAVEGEN_MFRQ;             // Use MFRQ so TOP can be set by CC[0] in COUNT16 mode
  TC3->COUNT16.CC[0].reg = 0x7a12;                           // Sets 2 sec pulse
  while (TC3->COUNT16.SYNCBUSY.bit.CC0);                     // Wait for synchronization
  TC3->COUNT16.INTENSET.bit.MC0 = 1;                         // enable interrupt on COMPARE0
  TC3->COUNT16.CTRLA.bit.ENABLE = 1;                         // Enable timer TC3
  while (TC3->COUNT16.SYNCBUSY.bit.ENABLE);                  // Wait for synchronization
  NVIC_SetPriority(TC3_IRQn, 0);
  NVIC_EnableIRQ(TC3_IRQn);
void loop()  {
void TC3_Handler() {
  TC3->COUNT16.INTFLAG.bit.MC0 = 1;                         // IMPORTANT! reset interrupt flag!
  digitalWrite(togglePin, 0);
  //set flag for erase function
void swISR()  {
  //trigger one-shot timer here
  TC3->COUNT16.CTRLBSET.reg |= 0b00100000;   //RETRIGGER counter
  digitalWrite(togglePin, 1);
  //print notificaton on TFT.  Erase in interrupt handler.
Jon
stratosfear
by FlatCat on Thu Jul 16, 2020 4:30 pm
These are great! Thanks stratosfear.
FlatCat
