Grand Central in standby sleep mode
by oferzv on Tue Mar 03, 2020 2:34 pm
HI all,
I am starting to work with the grand central and having problems getting to micro amp current levels in standby sleep mode.
When i execute the code below i get a current consumption of 7-9 mA How can I achieve better results ?
USBDevice.detach();
USBDevice.end();
USBDevice.standby();
PM->SLEEPCFG.bit.SLEEPMODE = 0x4;
while (PM->SLEEPCFG.bit.SLEEPMODE != 0x4);
__DSB();
__WFI();
Thanks for the help
oferzv
Re: Grand Central in standby sleep mode
by adafruit_support_mike on Mon Mar 16, 2020 3:33 am
You'd have to remove a lot of chips from the board.
Low-power design is a specialty field, and that wasn't a design priority for the Grand Central. The NeoPixel draws about 1mA on its own, the circuit that controls the 5V regulator draws some current, and so on.
It's easier to use an external low-power timer like the TPL5110:
https://www.adafruit.com/product/3435
It uses less than 100nA if you cut the jumper to the power LED on the back, and about 20uA if you don't.
