UUID from Grand Central
by FlatCat on Tue Mar 10, 2020 10:04 am
Does anyone know how to get the UUID from the SAMD51 of a Grand Central? I have code for doing this on an Arduino DUE, but it is a different processor. (SAM3X).
FlatCat
Re: UUID from Grand Central
by mikeysklar on Tue Mar 10, 2020 12:05 pm
Hi FlatCat,
Good question about reading UUID's on a m4 system using Arduino code.
It looks like you should be able to modify the ArduinoUniqueID code with the address for an m4 processor.
https://github.com/ricaun/ArduinoUniqueID
SAMD51: 128bit (4x 32bit) uid is stored in Flash (nvm) @ these addresses: 0x008061FC, 0x00806010, 0x00806014, 0x00806018
The SAMD21 address are slightly different, but this might be helpful for finding them.
SAMD21: 128bit (4x 32bit) uid is stored in Flash (nvm) @ these addresses: 0x0080A00C, 0x0080A040, 0x0080A044, 0x0080A048.
addresses taken from this 2017 github thread and UUID.
https://github.com/adafruit/circuitpyth ... it-40d63dd
mikeysklar
by FlatCat on Tue Mar 10, 2020 6:12 pm
Thanks, Mike. But I'm not sure how to read those locations since the Grand Central page says there is no support for nvm "eeprom'. Or is that independent?
FlatCat
by mikeysklar on Tue Mar 10, 2020 6:27 pm
I suspect it will still work if you add a new arch here for the SAMD51 with the only difference being the four addresses:
https://raw.githubusercontent.com/ricau ... iqueID.cpp
#elif defined(ARDUINO_ARCH_SAMD)
   // from section 9.3.3 of the datasheet
   #define SERIAL_NUMBER_WORD_0   *(volatile uint32_t*)(0x0080A00C)
   #define SERIAL_NUMBER_WORD_1   *(volatile uint32_t*)(0x0080A040)
   #define SERIAL_NUMBER_WORD_2   *(volatile uint32_t*)(0x0080A044)
   #define SERIAL_NUMBER_WORD_3   *(volatile uint32_t*)(0x0080A048)
   uint32_t pdwUniqueID[4];
   pdwUniqueID[0] = SERIAL_NUMBER_WORD_0;
   pdwUniqueID[1] = SERIAL_NUMBER_WORD_1;
   pdwUniqueID[2] = SERIAL_NUMBER_WORD_2;
   pdwUniqueID[3] = SERIAL_NUMBER_WORD_3;
   for (int i = 0; i < 4; i++)
      id[i*4+0] = (uint8_t)(pdwUniqueID[i] >> 24);
      id[i*4+1] = (uint8_t)(pdwUniqueID[i] >> 16);
      id[i*4+2] = (uint8_t)(pdwUniqueID[i] >> 8);
      id[i*4+3] = (uint8_t)(pdwUniqueID[i] >> 0);
mikeysklar
by User_UMjT7KxnxP8YN8 on Wed Mar 11, 2020 3:28 pm
I do it like this on the Metro M4 Express with the same MCU:
void getMCU_ID(uint32_t* MCU_ID) {
  // These are the addresses of the 4 32-bit MCU serial number values for the SAMD51 MCU. Combined, they form a unique 128-bit serial number.
#define SN_WORD_0  (uint32_t*)0x008061FCUL
#define SN_WORD_1  (uint32_t*)0x00806010UL
#define SN_WORD_2  (uint32_t*)0x00806014UL
#define SN_WORD_3  (uint32_t*)0x00806018UL
  MCU_ID[0] = *SN_WORD_0;
  MCU_ID[1] = *SN_WORD_1;
  MCU_ID[2] = *SN_WORD_2;
  MCU_ID[3] = *SN_WORD_3;
}   // getMCU_ID
User_UMjT7KxnxP8YN8
by FlatCat on Thu Mar 12, 2020 1:02 pm
I tried these but the program hangs when it gets to the first statement. In the library for SAMD21 there are some statements setting EFC1 and STUI-related registers. Are those not required here?
FlatCat
by mikeysklar on Thu Mar 12, 2020 5:46 pm
I don't think the EFC1 and STUI lines are necessary for just reading the UUID registers. Comment them out.
mikeysklar
by User_UMjT7KxnxP8YN8 on Fri Mar 13, 2020 2:36 pm
My function should be called like this:
  uint32_t mcu_id[4];
  getMCU_ID(mcu_id);
User_UMjT7KxnxP8YN8
by FlatCat on Thu Jul 16, 2020 12:45 pm
This works! Thanks.
FlatCat
