Basic math function
Basic math function
by AH3000bt7 on Mon Mar 16, 2020 1:46 pm
Looking for the basic math function . Have loaded latest MU editor and upgrade for Grand central station . Mu editor indicated no faults but Repl on boot shows faults .
One line is problem
Line 41
While True:
If Switch1. value > C :
The Repl states line 41
TypeError: unsupported for __gt__: 'Direction' , 'int
Have no problems with the setup of input and output prior to line 41
Have looked for basic math ( >,< ,&,+ ,= ,- ) in documentation and have not been able to find any for CircuitPython
AH3000bt7
Re: Basic math function
by westfw on Mon Mar 16, 2020 4:18 pm
I believe the complaint is that one of the variables in your if statement is a "direction", and one of them is just an "integer", and there is no implemented way to compare them (it'd be like "is North greater than 10")
It make sense that the editor would not detect this level of error; syntactically, it's fine, and the failure depends on the types that the variables have at run-time.
westfw
by AH3000bt7 on Mon Mar 16, 2020 6:48 pm
Your statement makes sense . Thanks for the reply
I was under the impression that an input .value could only be 1 or 0 . true or false
The C can it be set to one of these, with in a math statement. ?
As I need to compare apples to apples and not 10 to the north
AH3000bt7
by AH3000bt7 on Mon Mar 16, 2020 7:46 pm
AH3000bt7
by westfw on Mon Mar 16, 2020 11:16 pm
I can't tell without seeing more of the code you're trying to use.
westfw
