Output Oscillator to GPIO on grand central
by talofer99 on Thu Mar 19, 2020 7:03 am
I'm trying to output the external 32K oscillator to a GPIO on the board, I manged to find few similar examples, but none seemed to work.
This is the last code that I tried and was expecting to see the clock on the PA17 GPIO.
I'm using Platform-IO for coding and compiling.
Any input would be great
#include <Arduino.h>
#if defined(ARDUINO_SAMD_ZERO) && defined(SERIAL_PORT_USBVIRTUAL)
// Required for Serial on Zero based boards
#define Serial SERIAL_PORT_USBVIRTUAL
#endif
  Serial.begin(115200);
  while (!Serial);
  pinMode(36,OUTPUT);
  pinMode(5,OUTPUT);
  OSC32KCTRL->XOSC32K.bit.CGM = 1; // control gain mode: 1 = standard/XT 2 = high-speed/HS
  OSC32KCTRL->XOSC32K.bit.STARTUP = 0; // oscillator startup time, 0 = 62 ms
  OSC32KCTRL->XOSC32K.bit.ONDEMAND = 1; // always run
  OSC32KCTRL->XOSC32K.bit.XTALEN = 1; // enable crystal driver circuit for XIN32/XOUT32 pins
  OSC32KCTRL->XOSC32K.bit.EN32K = 1; // enable the 32 kHz output clock
  OSC32KCTRL->XOSC32K.bit.ENABLE = 1;
  while (!OSC32KCTRL->STATUS.bit.XOSC32KRDY); // wait until crystal oscillator is stable and ready to be used as a clock source
  GCLK->PCHCTRL[TC3_GCLK_ID].reg = GCLK_PCHCTRL_GEN_GCLK1_Val |
                                   (1 << GCLK_PCHCTRL_CHEN_Pos);
  GCLK->GENCTRL[3].bit.SRC = 0x5;
  GCLK->GENCTRL[3].bit.DIV = 1;
  GCLK->GENCTRL[3].bit.GENEN = 1;
  GCLK->GENCTRL[3].bit.IDC = 1 ;
  GCLK->GENCTRL[3].bit.OOV = 1;
  while ( GCLK->SYNCBUSY.reg & GCLK_SYNCBUSY_GENCTRL3 ){
    /* Wait for synchronization */
  PORT->Group[0].PINCFG[17].bit.PMUXEN = 1;
  PORT->Group[0].PMUX[8].bit.PMUXE = 0xc;
  Serial.println("setup done");
void loop(){ }
talofer99
Re: Output Oscillator to GPIO on grand central
by MartinL2 on Fri Mar 20, 2020 10:48 am
Hi talofer99,
The following code will output the 32.768kHz external crystal on port pin PA17 via GCLK3:
// Output the 32.768kHz external crystal on port pin PA17 via GCLK3
  GCLK->GENCTRL[3].reg = GCLK_GENCTRL_OE |                    // Enable GCLK3 output
                         GCLK_GENCTRL_IDC |                   // Improve duty-cycle to 50%
                         GCLK_GENCTRL_GENEN |                 // Enable generic clock
                         GCLK_GENCTRL_SRC_XOSC32K;            // Set the clock source to the external 32.768kHz crystal
  while (GCLK->SYNCBUSY.bit.GENCTRL3);                        // Wait for synchronization
  PORT->Group[PORTA].PINCFG[17].bit.PMUXEN = 1;               // Switch port pin PA17's multiplexer
  PORT->Group[PORTA].PMUX[17 >> 1].reg |= PORT_PMUX_PMUXO(MUX_PA17M_GCLK_IO3);  // Switch the PA17's port multiplexer to GCLK IO
void loop() {}
MartinL2
by talofer99 on Fri Mar 20, 2020 12:09 pm
Thank you very much, worked like magic :)
talofer99
