Metro 328 not recognized by my macOS
Re: Metro 328 not recognized by my macOS
by T__K on Thu Apr 16, 2020 6:52 pm
I downloaded the legacy USB driver as suggested in the info you sent. Unfortunately, the results are the same. Details are as follows:
Ran “uninstaller.sh” to uninstall the current version. And rebooted the computer.
Unzipped the downloaded “Mac_OSX_VCP_Driver_10_6.zip” file, double-clicked “SiLabsUSBDriverDisk.dmg”, which opened a folder, and double-clicked “Silicon Labs VCP Driver.pkg”
Message: “The Silicon Labs VCP Driver has been successfully installed.”
The driver is “CP210x Macintosh OSX VCP Driver 4.x.14 - November 3, 2016. This release includes the Macintosh OSX driver for the Intel and
PowerPC Platforms versions 10.5, 10.6, 10.7, 10.8, 10.9, 10.10 and 10.11.”
Connected the Metro.
The “Terminal” method (entering “ls /dev/cu*) produces this output:
/dev/cu.Bluetooth-Incoming-Port /dev/cu.MindWaveMobile-SerialPo-21
The “About this Mac” method produces this output:
CP2104 USB to UART Bridge Controller:
Product ID: 0xea60
Vendor ID: 0x10c4 (Silicon Laboratories, Inc.)
Version: 1.00
Serial Number: 01BE20E6
Speed: Up to 12 Mb/sec
Manufacturer: Silicon Labs
Location ID: 0xfa130000 / 6
Current Available (mA): 500
Current Required (mA): 100
Extra Operating Current (mA): 0
On a different topic, I noticed the time on the posts is 5 hours later than for my home, and am curious where you're located (or is it the servers?) I'm in Toronto, Canada.
Also, I hope this post will not somehow alert you and wake you up.
T__K
by adafruit_support_carter on Fri Apr 17, 2020 1:33 pm
No worries. Post whenever you want. :)
Weird issue. Let me pass this on and see if anyone else has ideas.
by adafruit2 on Fri Apr 17, 2020 1:49 pm
can you try going thru a hub? whatst he output from `sudo dmesg`?
adafruit2
Site Admin
by T__K on Fri Apr 17, 2020 5:26 pm
Connected thru a hub (from Adafruit). Looks like the same result:
"Terminal" method:
ls /dev/cu*
“About this Mac” method:
Product ID: 0xea60
Version: 1.00
Location ID: 0xfa134000 / 7
Entered "sudo dmesg" in the Terminal. Output is very long. I estimate about 330 lines. File is uploaded.
sudo dmesg Apr 17.txt
(16.02 KiB) Downloaded 3 times
T__K
by T__K on Fri Apr 17, 2020 7:00 pm
I should have mentioned in my most recent reply that my computer still had the legacy USB driver installed when I produced the results (CP210x Macintosh OSX VCP Driver 4.x.14 - November 3, 2016)
The results thru the hub with the most recent driver are below. (CP210x Macintosh OSX VCP Driver 5.3.5, Feb. 25, 2020)
"Terminal" method:
ls /dev/cu*
Product ID: 0xea60
Version: 1.00
sudo dmesg file is attached.
There are instructions in this version about displaying the log file. It is below:
Last login: Fri Apr 17 18:49:26 on ttys000
Tony-Kicinskis-iMac:~ tonykicinski$ tail -f ~/Library/Log/silabs_vcp_installer.log
installing the helper...
helper tool installed
RemoteCall: installKextFromBundle /Volumes/Silicon Labs VCP Driver Install Disk/Install CP210x VCP Driver.app
DONE installKextFromBundle: kOSKextReturnAuthentication (-603946995)
Checking currentlyLoadedCP210xDriverVersion...
did not find the CP210xDriver using kextstat.
setupSummary. kextstatVer = (null) ver2Install = 5.3.5 verFS = 5.3.5
Step: Summary
appShouldTerminate: NSTerminateNow
applicationWillTerminate received.
There's also an info.txt file mentioned with this version. It's uploaded.
info8.txt
(55.05 KiB) Downloaded 3 times
sudo dmesg newest driver.txt
(16.02 KiB) Downloaded 4 times
T__K
by adafruit2 on Sat Apr 18, 2020 9:52 pm
did you reboot?
adafruit2
Site Admin
by T__K on Sun Apr 19, 2020 10:23 am
Oh-oh! I may have forgotten to reboot after uninstalling the previous driver. Sorry!
Here is what I have done now:
Rebooted the computer.
Used the installer located in the “Troubleshooting” folder, which the troubleshooting text states is the Apple installer.
Connected the Metro (thru the hub). Results:
“Terminal” method:
ls /dev/cu*
Product ID: 0xea60
Version: 1.00
Log file:
Last login: Sun Apr 19 09:41:20 on ttys000
Step: Summary
Results of “sudo dmesg” are in a file. (Uploaded)
Saved “info9.txt” file. (Uploaded)
Also uploaded Silicon Labs' troubleshooting instructions, for your info.
Would it be useful if I reboot now and send you all the above info?
Thank you for investigating this problem.
Troubleshooting.txt
(2.97 KiB) Downloaded 2 times
info9.txt
(55 KiB) Downloaded 1 time
sudo dmesg Apr 19, 9-45 am.txt
(16.06 KiB) Downloaded 3 times
T__K
by adafruit2 on Sun Apr 19, 2020 11:57 am
thanx - did you reboot after installing the driver?
adafruit2
Site Admin
by T__K on Sun Apr 19, 2020 1:55 pm
No, I didn't. When I read the install instructions, I thought that rebooting was recommended after uninstalling, but I didn't see anything about rebooting after installing. (Maybe I missed it?)
Here is what I did now:
Rebooted the computer. (Did not reinstall the driver this time)
“Terminal” method:
ls /dev/cu*
Product ID: 0xea60
Version: 1.00
Location ID: 0xfa134000 / 6
Log file:
Last login: Sun Apr 19 13:24:29 on ttys000
Step: Summary
Saved “info10.txt” file. (Uploaded)
info10.txt
(55.05 KiB) Downloaded 1 time
sudo dmesg Apr 19 1-30pm.txt
(16.06 KiB) Downloaded 2 times
T__K
by adafruit2 on Sun Apr 19, 2020 2:24 pm
hmm tahts all the suggestions we have. there's something with your OS that isnt recognizing the SiLab CP2104 driver...the hardware seems to be ok. if you cant use it with another computer email support@adafruit for a refund
adafruit2
Site Admin
by T__K on Sun Apr 19, 2020 2:42 pm
Too bad that it's something strange in my computer's OS.
T__K
by cineman on Thu Jul 30, 2020 5:47 pm
i also have a problem getting a usb port to my new metro. never used one before. -metro arrived connected to my mac via usb but not recognized. using OS X 10.10.5. however, my computer continues to recognize my arduino uno and offers me the usb port under tools, port. i am stuck with the metro.
cineman
by adafruit_support_carter on Thu Jul 30, 2020 6:10 pm
@cineman Please start a new thread for your issue.
