Serial2 and Serial3 on Adafruit Grand Central M4
by hopskipjump on Tue Apr 28, 2020 10:04 am
For the Adafruit Grand Central M4 I thought that RX2 (pin17) and RX3 (pin 15) work with Serial2 and Serial3. But I get
error: 'Serial2' was not declared in this scope
and
error: 'Serial3' was not declared in this scope
Are these expected to work?
hopskipjump
Re: Serial2 and Serial3 on Adafruit Grand Central M4
by dastels on Tue Apr 28, 2020 11:36 am
It look like it's partially implemented, but the Uart objects aren't being created.
I 've been playing with this and getting some results with Serial2.
The exact file locations may/will be different on your system, but there shoudl be enough information in the paths for you to find it on your system.
In file ~/.arduino15/packages/adafruit/hardware/samd/1.5.11/variants/grand_central_m4/variant.h look for a line:
extern Uart Serial1;
Add a line after it:
extern Uart Serial2;
And one for Serial3 if you wish.
In file ~/.arduino15/packages/adafruit/hardware/samd/1.5.11/variants/grand_central_m4/variant.cpp look for a line:
Uart Serial1( &sercom0, PIN_SERIAL1_RX, PIN_SERIAL1_TX, PAD_SERIAL1_RX, PAD_SERIAL1_TX ) ;
As before, add after it:
Uart Serial2( &SERCOM_SERIAL2, PIN_SERIAL2_RX, PIN_SERIAL2_TX, PAD_SERIAL2_RX, PAD_SERIAL2_TX ) ;
And a similar one for Serial3 if desired.
dastels
by hopskipjump on Tue Apr 28, 2020 11:59 am
Thank you!
That resolved the error.
hopskipjump
by tomjennings on Fri Jul 03, 2020 2:30 pm
THANK YOU! Easy fix.
Is there a reason this isn't in the distribution as default?
One of the main reasons I have been using Mega 2560s, and now Grand Central's, is multiple hardware serials.
For mac users, the variant.* files are in /Users/username/Library/Arduino/packages/.... etc
tomjennings
by dastels on Fri Jul 03, 2020 5:24 pm
Agreed. I was surprised.
dastels
by tomjennings on Tue Jul 07, 2020 7:19 pm
Has anyone actually gotten additional UARTs working on Grand Central M4 Express? If so, could you be so kind as to post example code and config?
I'm stumped.
I'm getting hangs just TRANSMITTING. And the output pins remain LOW.
tomjennings
