Grand Central M4, get status of output pin
by psg1908 on Tue Jul 07, 2020 12:32 pm
There's a snippet of code I use (originally taken from an Arduino forum post) on an Arduino Mega to read the value of an output pin:
#include <wiring_private.h>
#include <pins_arduino.h>
#define A_PIN 2
bool getDir()
 uint8_t bit = digitalPinToBitMask(A_PIN);
 uint8_t port = digitalPinToPort(A_PIN);
 if (port == NOT_A_PIN)
   return LOW;
 return (*portOutputRegister(port) & bit) ? HIGH : LOW;
However in transitioning to my M4 this doesn't seem to be supported. Is there a method I can use to get the status of a digital output pin on my Grand Central M4?
To clarify, this is the error I am receiving in compiling the above code:
Arduino: 1.8.13 (Windows 10), Board: "Adafruit Grand Central M4 (SAMD51), Enabled, 120 MHz (standard), Small (-Os) (standard), 50 MHz (standard), Arduino, Off"
In file included from <...>\Arduino15\packages\adafruit\hardware\samd\1.5.14\cores\arduino/delay.h:24:0,
                 from <...>\Arduino15\packages\adafruit\hardware\samd\1.5.14\cores\arduino/Arduino.h:81,
                 from sketch
<...>: In function 'bool getDir()':
<...>\Arduino15\packages\adafruit\hardware\samd\1.5.14\variants\grand_central_m4/variant.h:66:38: error: invalid conversion from 'PortGroup*' to 'uint8_t {aka unsigned char}' [-fpermissive]
 #define digitalPinToPort(P)        ( &(PORT->Group[g_APinDescription[P].ulPort]) )
<...>: note: in expansion of macro 'digitalPinToPort'
<...>\Arduino15\packages\adafruit\hardware\samd\1.5.14\variants\grand_central_m4/variant.h:69:44: error: base operand of '->' is not a pointer
 #define portOutputRegister(port)   ( &(port->OUT.reg) )
<...>: note: in expansion of macro 'portOutputRegister'
exit status 1
Error compiling for board Adafruit Grand Central M4 (SAMD51).
psg1908
