METRO M0 EXPRESS WAVE FILES NOT PLAYING
by kgrove on Mon Mar 08, 2021 8:10 pm
So I've been going through the Audio Out lesson https://learn.adafruit.com/circuitpytho ... -audio-out and have been following every step they're telling me, even using the .wav file they provided, and all I'm getting is a quiet "pop" in my speaker.
I even went through the "Play a tone" sections before that. I was able to create a tone, so I know it's not the speaker.
import time
import board
from audiocore import WaveFile
try:
    from audioio import AudioOut
except ImportError:
    try:
        from audiopwmio import PWMAudioOut as AudioOut
    except ImportError:
        pass
wave_file = open("StreetChicken.wav", "rb")
wave = WaveFile(wave_file)
audio = AudioOut(board.A0)
while True:
    audio.play(wave)
I omitted the pause part of the lesson in this code, but I've tried both ways; still just the pop. Not sure what is wrong.
This lesson works, and creates a tone:
import time
import array
import math
import board
from audiocore import RawSample
try:
except ImportError:
    try:
    except ImportError:
        pass  # not always supported by every board!
tone_volume = 0.1  # Increase this to increase the volume of the tone.
frequency = 440  # Set this to the Hz of the tone you want to generate.
length = 8000 // frequency
sine_wave = array.array("H", [0] * length)
for i in range(length):
    sine_wave[i] = int((1 + math.sin(math.pi * 2 * i / length)) * tone_volume * (2 ** 15 - 1))
sine_wave_sample = RawSample(sine_wave)
while True:
    audio.play(sine_wave_sample)
Any suggestions?
kgrove
Re: METRO M0 EXPRESS WAVE FILES NOT PLAYING
by mikeysklar on Tue Mar 09, 2021 6:19 pm
I suspect you have the right code in place. As the examples look just like ours and you have a working tone.
This is probably going to come down to library release versus circuitpython release compatibility issue. Which version of each are you running?
Can you post a photo of your wiring so we can confirm it looks like the example:
mikeysklar
by kgrove on Tue Mar 16, 2021 3:21 pm
I have Adafruit CircuitPython 6.1.0 on 2021-01-21; Adafruit Grand Central M4 Express with samd51p20 and the TXT file attached as my libraries.
As you might have noticed, I am now using a Grand Central M4 Express. I tried setting up the audio the same way (see image for ref). I
started with the sine wave generator and got a sputtering of sound, then it stopped.
VERSIONS.txt
(20.95 KiB) Downloaded 2 times
kgrove
by kgrove on Tue Mar 16, 2021 5:59 pm
Actually I got it working. I didn't have a capacitor hooked up.
Is there any way to boost the signal beyond the highest level it is putting out?
kgrove
by mikeysklar on Wed Mar 17, 2021 1:12 pm
tone_volume in your code example is set to 0.1 by default so you can increase that up to 1 which will be painfully loud.
are you able to use the potentiometer to adjust the volume of the WavFile while playing?
mikeysklar
