Metro Mini won't upload sketch (Resource busy)
by nicknewhouse on Thu Mar 18, 2021 11:15 am
Hi all - I'm trying to test out my new Metro Mini w/ the blink sketch and I'm getting the same error every time I try to upload:
Arduino: 1.8.14 Hourly Build 2021/03/09 09:34 (Mac OS X), Board: "Arduino Uno"
Sketch uses 924 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
avrdude: ser_open(): can't open device "/dev/cu.usbserial-0209DCB6": Resource busy
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
I'm on OSX 10.15.7 using a micro USB data cable (I'm positive it's a data cable) connected to a USB hub.
Here's the part: Adafruit Metro Mini 328 - Arduino-Compatible - 5V 16MHz[ID:2590]
I've picked Arduino Uno as the board and the port is
Sorry if this is a basic question, I'm pretty sure I properly installed the SiliconLabs drivers and everything so I'm sort of at a loss.
nicknewhouse
Re: Metro Mini won't upload sketch (Resource busy)
by franklin97355 on Thu Mar 18, 2021 11:32 am
This is a tutorial in case you missed anything. https://learn.adafruit.com/adafruit-metro-mini#arduino-ide-usage
franklin97355
by nicknewhouse on Thu Mar 18, 2021 12:02 pm
franklin97355 wrote:This is a tutorial in case you missed anything. https://learn.adafruit.com/adafruit-metro-mini#arduino-ide-usage
Yeah unfortunately there's nothing in here that I haven't already done correctly I'm 99% sure
nicknewhouse
by adafruit_support_carter on Thu Mar 18, 2021 4:49 pm
Did the driver install seem to go OK?
https://learn.adafruit.com/adafruit-met ... -ide-usage
What is the port showing up as in the Mac's System Information?
by adafruit2 on Thu Mar 18, 2021 5:29 pm
also - to get ahead of possible bootloader issues: when you press the mini's bootloader button, does the red led flash a couple times?
adafruit2
Site Admin
by nicknewhouse on Thu Mar 25, 2021 5:00 pm
adafruit2 wrote:also - to get ahead of possible bootloader issues: when you press the mini's bootloader button, does the red led flash a couple times?
yes, the red led flashes a couple times
nicknewhouse
by nicknewhouse on Thu Mar 25, 2021 5:01 pm
adafruit_support_carter wrote:Did the driver install seem to go OK?
It shows up as:
CP2104 USB to UART Bridge Controller
Sorry for the late reply, I switched to my Windows machine and had better luck there. It might be worth resolving this for future MacOS Catalina users though
nicknewhouse
