Bug in CircuitPython Display Support Using displayio lesson
by kgrove on Sat Mar 20, 2021 1:48 pm
I'm going through the CircuitPython Display Support Using displayio lesson and trying to display some text on a 32x64 LED Matrix using my Grand Central M4 Express. I noticed that when I try to run the code
import board
import displayio
import terminalio
from adafruit_display_text import label
display = board.DISPLAY
# Set text, font, and color
text = "HELLO WORLD"
font = terminalio.FONT
color = 0x0000FF
# Create the text label
text_area = label.Label(font, text=text, color=color)
# Set the location
text_area.x = 100
text_area.y = 80
# Show it
display.show(text_area)
# Loop forever to prevent code from exiting
while True:
    pass
It throws an error
  File "code.py", line 6, in <module>
AttributeError: 'module' object has no attribute 'DISPLAY'
What is the solution?
https://learn.adafruit.com/circuitpython-display-support-using-displayio/text
kgrove
Re: Bug in CircuitPython Display Support Using displayio les
by adafruit_support_carter on Mon Mar 22, 2021 12:57 pm
This usage:
is only for boards with "built in" displays:
https://learn.adafruit.com/circuitpytho ... 3025839-19
For the GC, you'll need to do something like this:
https://learn.adafruit.com/circuitpytho ... 3077571-21
Since you are using an LED Matrix, the setup code in the MatrixPortal library may be useful:
https://github.com/adafruit/Adafruit_Ci ... /matrix.py
It comes down to using this:
https://circuitpython.readthedocs.io/en ... index.html
This is a good general RGB matrix w/ CircuitPython guide:
https://learn.adafruit.com/rgb-led-matr ... cuitpython
