Sgp4 lib error
Sgp4 lib error
by sashaT on Tue Apr 13, 2021 12:36 pm
Hi all,
I wanted to make a satellite tracker with the metro airlift m4. I tried the example code, https://github.com/Hopperpop/Sgp4-Libra ... dictor.ino, and changed the min variable to minutes as requested by the Arduino IDE. I uploaded the code, and get no serial output whatsoever, and the metro disconnecting from the COM port until I press the reset button two times. I really need this for a pass in two days.
sashaT
Re: Sgp4 lib error
by adafruit_support_carter on Tue Apr 13, 2021 1:07 pm
If you are having a basic issue getting the Metro to work, we can help with that. This would be something like you can not even load and run a basic blink example per the associated Metro guide (there are several different boards in the Metro line).
If your issue is with that Sgp4 library, please raise an issue with the library author:
https://github.com/Hopperpop/Sgp4-Library/issues
