I have been using this https://www.adafruit.com/product/50 Adafruit board for a project I'm working on. Recently, I have been unable to upload any sketch with the Arduino IDE (even the BareMinimum example) although the board was previously working normally. I've copied the error message below. Do you have any advice about how I can fix the board / get the board replaced? Thank you!
Arduino: 1.8.15 (Windows 10), Board: "Adafruit Metro"
Sketch uses 7512 bytes (23%) of program storage space. Maximum is 32256 bytes.
Global variables use 589 bytes (28%) of dynamic memory, leaving 1459 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:C:\Users\joelg\AppData\Local\Temp\arduino_build_950312/max31865.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM3
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x0e
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x0e
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x0e
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x0e
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x0e
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x0e
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x0e
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x0e
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x0e
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x0e
avrdude done. Thank you.
Problem uploading to board. See https://support.arduino.cc/hc/en-us/sections/360003198300 for suggestions.
