Metro M0 Express Library not Importing
violaEmperor
Post by violaEmperor »
I tried to run this circuitpython program today on my Metro M0 Express, I got the error message:
code.py output:
File "code.py", line 3, in <module>
AttributeError: 'module' object has no attribute 'time'
This is the test program I had uploaded.
import time
while True:
    print(time.time())
When I enter the REPL in mu though, it says Adafruit CircuitPython 2.2.0 on 2018-01-02; Adafruit Metro M0 Express with samd21g18. I tried to upload the Circuitpython 6.3.0 from the CircuitPython website, but I got the same results. I am on MacOS 10.15.7.
Thank you
dastels
Re: Metro M0 Express Library not Importing
Post by dastels »
Weird.
It's importing fine (it would explicitly say it couldn't import it)... it just doesn't see the time() method.
Try deleting and retyping (not copy/paste). Sometimes there are non-printing characters that get picked up.
Alternatively, what happens if you *type* this into the REPL?
import time
time.time()
violaEmperor
When I try it in the Repl, I get the error message
File "<stdin>", line 1, in <module>
Is it a problem with the version? Since the Repl says it's version 2.2.0, and I downloaded the 6.x.x libraries and I'm using the stable 6.3.0 release, could it be that there is some issue where the library versions don't line up? The circuitpython download said that time was a built in module.
violaEmperor
For some reason, when it works when I use the sleep method of time.
from time import sleep
while True:
sleep(1)
print("yes")
Is there something wrong with the circuitpython .uf2 file I downloaded?
Return to “Metro, Metro Express, and Grand Central Boards”
