Upload problem to Metro
flounder
Post by flounder »
I moved an app to the Metro to get more code space. But it won't upload. Sadly, Blink will not upload either. Here is what I see for Blink:
Sketch uses 11044 bytes (2%) of program storage space. Maximum is 507904 bytes.
Forcing reset using 1200bps open/close on port COM17
PORTS {COM13, COM17, } / {COM13, } => {}
PORTS {COM13, } / {COM13, } => {}
PORTS {COM13, } / {COM13, COM16, } => {COM16, }
Found upload port: COM16
___REMOVE___/bossac -i -d --port=COM16 -U -i --offset=0x4000 -w -v C:\Users\admin\AppData\Local\Temp\arduino_build_981444/Blink.ino.bin -R
java.io.IOException: Cannot run program "___REMOVE___/bossac": CreateProcess error=2, The system cannot find the file specified
	at java.lang.ProcessBuilder.start(ProcessBuilder.java:1048)
	at processing.app.helpers.ProcessUtils.exec(ProcessUtils.java:26)
	at cc.arduino.packages.Uploader.executeUploadCommand(Uploader.java:129)
	at cc.arduino.packages.uploaders.SerialUploader.runCommand(SerialUploader.java:383)
	at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:197)
	at cc.arduino.UploaderUtils.upload(UploaderUtils.java:77)
	at processing.app.SketchController.upload(SketchController.java:732)
	at processing.app.SketchController.exportApplet(SketchController.java:703)
	at processing.app.Editor$UploadHandler.run(Editor.java:2055)
	at java.lang.Thread.run(Thread.java:748)
Caused by: java.io.IOException: CreateProcess error=2, The system cannot find the file specified
	at java.lang.ProcessImpl.create(Native Method)
	at java.lang.ProcessImpl.<init>(ProcessImpl.java:386)
	at java.lang.ProcessImpl.start(ProcessImpl.java:137)
	at java.lang.ProcessBuilder.start(ProcessBuilder.java:1029)
	... 9 more
An error occurred while uploading the sketch
I don't know what __REMOVE__bossac is supposed to do, but I suspect that __REMOVE__ should have been removed. I am using Arduino IDE 1.8.13 on Windows 10. My board is a Metro M4 Express Beta.
Franklin97355
Re: Upload problem to Metro
Post by Franklin97355 »
When you plug the Metro in does your computer see it? Do you see a drive?
flounder
Post by flounder »
It does not appear as a drive. It does appear in the Arduino IDE as the port
COM17 (Adafruit Metro M4 (SAMD51))
The green ON led is on.
If I double-click reset, the NeoPixel (or DotStar) turns red, then green. The red LED labeled "L" starts fading in and out. The Arduino IDE reports port COM16 but without the annotation about being the Adafruit Metro M4.
However, in neither mode will it upload.
This is where it says COM17 (Adafruit Metro M4):
... long boring compilation output deleted...
Sketch uses 924 bytes (3%) of program storage space. Maximum is 30720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
C:\Users\admin\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\admin\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -PCOM17 -b57600 -D -Uflash:w:C:\Users\admin\AppData\Local\Temp\arduino_build_824175/Blink.ino.hex:i
avrdude: Version 6.3-20190619
         Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\admin\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
         Using Port                    : COM17
         Using Programmer              : arduino
         Overriding Baud Rate          : 57600
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xa9
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xa9
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xa9
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xa9
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xa9
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xa9
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xa9
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xa9
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xa9
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xa9
avrdude done.  Thank you.
Problem uploading to board.  See https://support.arduino.cc/hc/en-us/sections/360003198300 for suggestions.
My student dropped off three of his Arduino Nano clones, and I cannot upload to them, either. I cannot upload from my PC or my Mac. I have used different cables, including a brand-new (well, freshly-unwrapped) Adafruit USB-A<=>Micro B to the Metro
adafruit2
Post by adafruit2 »
"atmega328p" means you are trying to upload to an arduino UNO type. you have a metro m4, its a samd51
flounder
Post by flounder »
There are days in which I loathe the Arduino IDE. There are days that are much worse. It has trouble remembering what I was doing. Apparently, I had restarted it and it lost the board setting I had previously chosen.
It desperately needs the ability to read a JSON file in a set of /*...*/ comments that set all the parameters I need for a given compilation.
flounder
Post by flounder »
That said, nothing improved with selecting the correct board:
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware -hardware C:\Users\admin\Documents\ArduinoData\packages -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\admin\Documents\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\libraries -libraries C:\Users\admin\Documents\Arduino\libraries -fqbn=adafruit:samd:adafruit_metro_m0:opt=small,usbstack=arduino,debug=off -vid-pid=239A_8020 -ide-version=10815 -build-path C:\Users\admin\AppData\Local\Temp\arduino_build_824175 -warnings=more -build-cache C:\Users\admin\AppData\Local\Temp\arduino_cache_680384 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\admin\Documents\ArduinoData\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Users\admin\Documents\ArduinoData\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.bossac.path=C:\Users\admin\Documents\ArduinoData\packages\arduino\tools\bossac\1.7.0-arduino3 -prefs=runtime.tools.bossac-1.8.0-48-gb176eee.path=C:\Users\admin\Documents\ArduinoData\packages\arduino\tools\bossac\1.8.0-48-gb176eee -prefs=runtime.tools.CMSIS.path=C:\Users\admin\Documents\ArduinoData\packages\adafruit\tools\CMSIS\5.4.0 -prefs=runtime.tools.CMSIS-5.4.0.path=C:\Users\admin\Documents\ArduinoData\packages\adafruit\tools\CMSIS\5.4.0 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\admin\Documents\ArduinoData\packages\adafruit\tools\arm-none-eabi-gcc\9-2019q4 -prefs=runtime.tools.arm-none-eabi-gcc-9-2019q4.path=C:\Users\admin\Documents\ArduinoData\packages\adafruit\tools\arm-none-eabi-gcc\9-2019q4 -prefs=runtime.tools.CMSIS-Atmel.path=C:\Users\admin\Documents\ArduinoData\packages\arduino\tools\CMSIS-Atmel\1.2.0 -prefs=runtime.tools.CMSIS-Atmel-1.2.0.path=C:\Users\admin\Documents\ArduinoData\packages\arduino\tools\CMSIS-Atmel\1.2.0 -prefs=runtime.tools.bossac-1.7.0-arduino3.path=C:\Users\admin\Documents\ArduinoData\packages\arduino\tools\bossac\1.7.0-arduino3 -prefs=runtime.tools.openocd.path=C:\Users\admin\Documents\ArduinoData\packages\arduino\tools\openocd\0.10.0-arduino7 -prefs=runtime.tools.openocd-0.10.0-arduino7.path=C:\Users\admin\Documents\ArduinoData\packages\arduino\tools\openocd\0.10.0-arduino7 -verbose C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\examples\01.Basics\Blink\Blink.ino
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\arduino-builder -compile -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware -hardware C:\Users\admin\Documents\ArduinoData\packages -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\admin\Documents\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\libraries -libraries C:\Users\admin\Documents\Arduino\libraries -fqbn=adafruit:samd:adafruit_metro_m0:opt=small,usbstack=arduino,debug=off -vid-pid=239A_8020 -ide-version=10815 -build-path C:\Users\admin\AppData\Local\Temp\arduino_build_824175 -warnings=more -build-cache C:\Users\admin\AppData\Local\Temp\arduino_cache_680384 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\admin\Documents\ArduinoData\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Users\admin\Documents\ArduinoData\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.bossac.path=C:\Users\admin\Documents\ArduinoData\packages\arduino\tools\bossac\1.7.0-arduino3 -prefs=runtime.tools.bossac-1.8.0-48-gb176eee.path=C:\Users\admin\Documents\ArduinoData\packages\arduino\tools\bossac\1.8.0-48-gb176eee -prefs=runtime.tools.CMSIS.path=C:\Users\admin\Documents\ArduinoData\packages\adafruit\tools\CMSIS\5.4.0 -prefs=runtime.tools.CMSIS-5.4.0.path=C:\Users\admin\Documents\ArduinoData\packages\adafruit\tools\CMSIS\5.4.0 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\admin\Documents\ArduinoData\packages\adafruit\tools\arm-none-eabi-gcc\9-2019q4 -prefs=runtime.tools.arm-none-eabi-gcc-9-2019q4.path=C:\Users\admin\Documents\ArduinoData\packages\adafruit\tools\arm-none-eabi-gcc\9-2019q4 -prefs=runtime.tools.CMSIS-Atmel.path=C:\Users\admin\Documents\ArduinoData\packages\arduino\tools\CMSIS-Atmel\1.2.0 -prefs=runtime.tools.CMSIS-Atmel-1.2.0.path=C:\Users\admin\Documents\ArduinoData\packages\arduino\tools\CMSIS-Atmel\1.2.0 -prefs=runtime.tools.bossac-1.7.0-arduino3.path=C:\Users\admin\Documents\ArduinoData\packages\arduino\tools\bossac\1.7.0-arduino3 -prefs=runtime.tools.openocd.path=C:\Users\admin\Documents\ArduinoData\packages\arduino\tools\openocd\0.10.0-arduino7 -prefs=runtime.tools.openocd-0.10.0-arduino7.path=C:\Users\admin\Documents\ArduinoData\packages\arduino\tools\openocd\0.10.0-arduino7 -verbose C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\examples\01.Basics\Blink\Blink.ino
Using board 'adafruit_metro_m0' from platform in folder: C:\Users\admin\Documents\ArduinoData\packages\adafruit\hardware\samd\1.6.4
Using core 'arduino' from platform in folder: C:\Users\admin\Documents\ArduinoData\packages\adafruit\hardware\samd\1.6.4
Detecting libraries used...
"C:\\Users\\admin\\Documents\\ArduinoData\\packages\\adafruit\\tools\\arm-none-eabi-gcc\\9-2019q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions "-D__SKETCH_NAME__=\"\"\"Blink.ino\"\"\"" -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD -D__SAMD21G18A__ -DARDUINO_SAMD_ZERO -DARM_MATH_CM0PLUS -DADAFRUIT_METRO_M0_EXPRESS -DUSB_VID=0x239A -DUSB_PID=0x8013 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Metro M0 Express\"" "-IC:\\Users\\admin\\Documents\\ArduinoData\\packages\\adafruit\\hardware\\samd\\1.6.4\\cores\\arduino/TinyUSB" "-IC:\\Users\\admin\\Documents\\ArduinoData\\packages\\adafruit\\hardware\\samd\\1.6.4\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\admin\\Documents\\ArduinoData\\packages\\adafruit\\hardware\\samd\\1.6.4\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -Os -D__SAMD21G18A__ -DARDUINO_SAMD_ZERO -DARM_MATH_CM0PLUS -DADAFRUIT_METRO_M0_EXPRESS -DUSB_VID=0x239A -DUSB_PID=0x8013 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Metro M0 Express\"" "-IC:\\Users\\admin\\Documents\\ArduinoData\\packages\\adafruit\\hardware\\samd\\1.6.4\\cores\\arduino/TinyUSB" "-IC:\\Users\\admin\\Documents\\ArduinoData\\packages\\adafruit\\hardware\\samd\\1.6.4\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\admin\\Documents\\ArduinoData\\packages\\adafruit\\hardware\\samd\\1.6.4\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" "-IC:\\Users\\admin\\Documents\\ArduinoData\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/Core/Include/" "-IC:\\Users\\admin\\Documents\\ArduinoData\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/DSP/Include/" "-IC:\\Users\\admin\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\admin\\Documents\\ArduinoData\\packages\\adafruit\\hardware\\samd\\1.6.4\\cores\\arduino" "-IC:\\Users\\admin\\Documents\\ArduinoData\\packages\\adafruit\\hardware\\samd\\1.6.4\\variants\\metro_m0" "C:\\Users\\admin\\AppData\\Local\\Temp\\arduino_build_824175\\sketch\\Blink.ino.cpp" -o nul
Generating function prototypes...
"C:\\Users\\admin\\Documents\\ArduinoData\\packages\\adafruit\\tools\\arm-none-eabi-gcc\\9-2019q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions "-D__SKETCH_NAME__=\"\"\"Blink.ino\"\"\"" -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD -D__SAMD21G18A__ -DARDUINO_SAMD_ZERO -DARM_MATH_CM0PLUS -DADAFRUIT_METRO_M0_EXPRESS -DUSB_VID=0x239A -DUSB_PID=0x8013 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Metro M0 Express\"" "-IC:\\Users\\admin\\Documents\\ArduinoData\\packages\\adafruit\\hardware\\samd\\1.6.4\\cores\\arduino/TinyUSB" "-IC:\\Users\\admin\\Documents\\ArduinoData\\packages\\adafruit\\hardware\\samd\\1.6.4\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\admin\\Documents\\ArduinoData\\packages\\adafruit\\hardware\\samd\\1.6.4\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -Os -D__SAMD21G18A__ -DARDUINO_SAMD_ZERO -DARM_MATH_CM0PLUS -DADAFRUIT_METRO_M0_EXPRESS -DUSB_VID=0x239A -DUSB_PID=0x8013 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Metro M0 Express\"" "-IC:\\Users\\admin\\Documents\\ArduinoData\\packages\\adafruit\\hardware\\samd\\1.6.4\\cores\\arduino/TinyUSB" "-IC:\\Users\\admin\\Documents\\ArduinoData\\packages\\adafruit\\hardware\\samd\\1.6.4\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\admin\\Documents\\ArduinoData\\packages\\adafruit\\hardware\\samd\\1.6.4\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" "-IC:\\Users\\admin\\Documents\\ArduinoData\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/Core/Include/" "-IC:\\Users\\admin\\Documents\\ArduinoData\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/DSP/Include/" "-IC:\\Users\\admin\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\admin\\Documents\\ArduinoData\\packages\\adafruit\\hardware\\samd\\1.6.4\\cores\\arduino" "-IC:\\Users\\admin\\Documents\\ArduinoData\\packages\\adafruit\\hardware\\samd\\1.6.4\\variants\\metro_m0" "C:\\Users\\admin\\AppData\\Local\\Temp\\arduino_build_824175\\sketch\\Blink.ino.cpp" -o "C:\\Users\\admin\\AppData\\Local\\Temp\\arduino_build_824175\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\admin\\AppData\\Local\\Temp\\arduino_build_824175\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\admin\\Documents\\ArduinoData\\packages\\adafruit\\tools\\arm-none-eabi-gcc\\9-2019q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -Wall -Wno-expansion-to-defined -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD "-D__SKETCH_NAME__=\"\"\"Blink.ino\"\"\"" -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD -D__SAMD21G18A__ -DARDUINO_SAMD_ZERO -DARM_MATH_CM0PLUS -DADAFRUIT_METRO_M0_EXPRESS -DUSB_VID=0x239A -DUSB_PID=0x8013 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Metro M0 Express\"" "-IC:\\Users\\admin\\Documents\\ArduinoData\\packages\\adafruit\\hardware\\samd\\1.6.4\\cores\\arduino/TinyUSB" "-IC:\\Users\\admin\\Documents\\ArduinoData\\packages\\adafruit\\hardware\\samd\\1.6.4\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\admin\\Documents\\ArduinoData\\packages\\adafruit\\hardware\\samd\\1.6.4\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -Os -D__SAMD21G18A__ -DARDUINO_SAMD_ZERO -DARM_MATH_CM0PLUS -DADAFRUIT_METRO_M0_EXPRESS -DUSB_VID=0x239A -DUSB_PID=0x8013 -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Metro M0 Express\"" "-IC:\\Users\\admin\\Documents\\ArduinoData\\packages\\adafruit\\hardware\\samd\\1.6.4\\cores\\arduino/TinyUSB" "-IC:\\Users\\admin\\Documents\\ArduinoData\\packages\\adafruit\\hardware\\samd\\1.6.4\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\\Users\\admin\\Documents\\ArduinoData\\packages\\adafruit\\hardware\\samd\\1.6.4\\cores\\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" "-IC:\\Users\\admin\\Documents\\ArduinoData\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/Core/Include/" "-IC:\\Users\\admin\\Documents\\ArduinoData\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/DSP/Include/" "-IC:\\Users\\admin\\Documents\\ArduinoData\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\admin\\Documents\\ArduinoData\\packages\\adafruit\\hardware\\samd\\1.6.4\\cores\\arduino" "-IC:\\Users\\admin\\Documents\\ArduinoData\\packages\\adafruit\\hardware\\samd\\1.6.4\\variants\\metro_m0" "C:\\Users\\admin\\AppData\\Local\\Temp\\arduino_build_824175\\sketch\\Blink.ino.cpp" -o "C:\\Users\\admin\\AppData\\Local\\Temp\\arduino_build_824175\\sketch\\Blink.ino.cpp.o"
Compiling libraries...
Compiling core...
Using previously compiled file: C:\Users\admin\AppData\Local\Temp\arduino_build_824175\core\variant.cpp.o
Using precompiled core: C:\Users\admin\AppData\Local\Temp\arduino_cache_680384\core\core_bb06c8810e591b3e563af4a101e35514.a
Linking everything together...
"C:\\Users\\admin\\Documents\\ArduinoData\\packages\\adafruit\\tools\\arm-none-eabi-gcc\\9-2019q4/bin/arm-none-eabi-g++" "-LC:\\Users\\admin\\AppData\\Local\\Temp\\arduino_build_824175" -Os -Wl,--gc-sections -save-temps "-TC:\\Users\\admin\\Documents\\ArduinoData\\packages\\adafruit\\hardware\\samd\\1.6.4\\variants\\metro_m0/linker_scripts/gcc/flash_with_bootloader.ld" "-Wl,-Map,C:\\Users\\admin\\AppData\\Local\\Temp\\arduino_build_824175/Blink.ino.map" --specs=nano.specs --specs=nosys.specs -mcpu=cortex-m0plus -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -o "C:\\Users\\admin\\AppData\\Local\\Temp\\arduino_build_824175/Blink.ino.elf" "C:\\Users\\admin\\AppData\\Local\\Temp\\arduino_build_824175\\sketch\\Blink.ino.cpp.o" "C:\\Users\\admin\\AppData\\Local\\Temp\\arduino_build_824175\\core\\variant.cpp.o" -Wl,--start-group "-LC:\\Users\\admin\\Documents\\ArduinoData\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/Lib/GCC/" -larm_cortexM0l_math "-LC:\\Users\\admin\\Documents\\ArduinoData\\packages\\adafruit\\hardware\\samd\\1.6.4\\variants\\metro_m0" -lm "C:\\Users\\admin\\AppData\\Local\\Temp\\arduino_build_824175/..\\arduino_cache_680384\\core\\core_bb06c8810e591b3e563af4a101e35514.a" -Wl,--end-group
"C:\\Users\\admin\\Documents\\ArduinoData\\packages\\adafruit\\tools\\arm-none-eabi-gcc\\9-2019q4/bin/arm-none-eabi-objcopy" -O binary "C:\\Users\\admin\\AppData\\Local\\Temp\\arduino_build_824175/Blink.ino.elf" "C:\\Users\\admin\\AppData\\Local\\Temp\\arduino_build_824175/Blink.ino.bin"
"C:\\Users\\admin\\Documents\\ArduinoData\\packages\\adafruit\\tools\\arm-none-eabi-gcc\\9-2019q4/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom "C:\\Users\\admin\\AppData\\Local\\Temp\\arduino_build_824175/Blink.ino.elf" "C:\\Users\\admin\\AppData\\Local\\Temp\\arduino_build_824175/Blink.ino.hex"
"C:\\Users\\admin\\Documents\\ArduinoData\\packages\\adafruit\\tools\\arm-none-eabi-gcc\\9-2019q4/bin/arm-none-eabi-size" -A "C:\\Users\\admin\\AppData\\Local\\Temp\\arduino_build_824175/Blink.ino.elf"
Sketch uses 10544 bytes (4%) of program storage space. Maximum is 262144 bytes.
C:\Users\admin\Documents\ArduinoData\packages\arduino\tools\bossac\1.7.0-arduino3/bossac.exe -i -d --port=COM16 -U true -i -e -w -v C:\Users\admin\AppData\Local\Temp\arduino_build_824175/Blink.ino.bin -R
That is the last I see of it. It hangs there for a long time, and finally spews out
Set binary mode
No device found on COM16
readWord(addr=0)=0x2000d6a0
readWord(addr=0xe000ed00)=0x410fc241
Return to “Metro, Metro Express, and Grand Central Boards”
