M4 Express AirLift Lite and MySQL
AlexJustAlex
Post by AlexJustAlex »
Hi I have a small project to build a portable device to log various voltages and store them in an existing MySQL database.
After much hunting around I settled on an Adafruit Metro M4 Express AirLift (WiFi) - Lite with an appropriate ADC.
I'm quite familiar with python, so it seemed a good oportunity to get to grips with circuitpython.
While waiting for it to arrive I started looking around for some examples of using circuitpython with MySQL and I couldn't find any!
WIll I be able to use pymysql as I do in regular python projects or is there a circuitpython alternative or I have I made a foolish purchase?
thanks in advance for any help or pointers in the right direction
cheers
Alex
dastels
Re: M4 Express AirLift Lite and MySQL
Post by dastels »
MySQL (or any "real" database) is far beyond the capabilities of a SAMD51 (i.e. the "M4" in Metro M4). Since you have the AirLift Metro, you have some options:
- you can have it send readings to a MySQL service running on another machine, likely through MQTT or a RESTful web service
- you can send the readings (again via REST or MQTT) to Adafruit IO... this is much like the above except that the service is there already.
- you can add a SDcard shield/breakout and store readings in a file, and occasionally send that somewhere.
A bigger question is "What would you do with the data once it was in the DB?" Is there value in keeping it on the Metro?
AlexJustAlex
Thank you Dave.
To clarify:
the MySQL database already exists and is running on an appropriate server.
This database is part of a Meteorological Observatory and stores data from numerous instruments. (https://weybourne.uea.ac.uk/currentData.php)
The data makes its way to the database via a wide variety of solutions.
We sometimes add sensors for a brief period that will output data as an analogue voltage which I want to capture with some kind of portable device and then store on the database.
I do not need the data to be stored on the device.
I could do this with a Pi zero W, but I fancied trying something different.
The M4 Express AirLift Lite seemd like an interesting route to pursue, although perhaps I should have sone a bit more research first!
So the general idea is:
  • read a voltage
    connect to database on same lan over wifi
    insert reading in table
    disconnect
    wait a bit
    repeat
Nothing too taxing if the Metro can handle the MySQL conneciton
My question was can it?
Thanks for the pointers to MQTTand RESTful , I know absolutely nothing about either and it looks like I should!
In this instance if I can't do a simple MySQL connection, or, if not, get my head around one of those within a day, I'll probably put the Metro to one side and chalk that one up to experience, grab a Pi zero W and leave the Metro, MQTT and RESTful for some point when I have a bit more time.
your help is much appreciated
cheers
Alex
AlexJustAlex
If I can't connect directly to the MySQL server, I think it looks like I can use adafruit-circuitpython-requests to post the data to a webpage that will handle the actual insert
Alex
dastels
Post by dastels »
Ah, you should be fine then. The M4 Airlift is perfect for taking readings and sending them off to a server. The only question is accessing MySQL, but I would be very shocked if someone hasn't made MQTT or RESTful interfaces for it.
dastels
Post by dastels »
As AlexJustAlex said, you may be able to connect directly to the MySQL service. It is, afterall, just a WiFi connection.
Return to “Metro, Metro Express, and Grand Central Boards”
