hello Adafruit peeps - a noob looking for some help.
First off, I'm loving the Learn guides, really well done.
I'm running into an issue i cannot find a solution for - I'm trying to use the basic MQTT project guide with a Metro M4 Airlift Lite - following the online guide, running the latest CircuitPython 7.x version and trying to load the basic Project Bundle - upon save/load the serial monitor reports out the following error
File "code.py", line 4, in <module>
ImportError: no module named 'ssl'
I've copied over all the files that i can see included in the download project??? please help a noob by pointing out what i'm doing wrong - much appreciated....
Thanks M
Metro M4 Airlift Lite and MQTT project bundle
- Martinsoanes
- Franklin97355
Re: Metro M4 Airlift Lite and MQTT project bundle
Which guide did you follow and what code did you try to run? Did you load the correct uf2 file and python for V7?
- Martinsoanes
thanks - i hope i used the correct references
I first updated the Metro m4 airlift lite from link on this page:
https://learn.adafruit.com/adafruit-met ... bootloader that took me here
https://circuitpython.org/board/metro_m4_airlift_lite/
once the latest uf2 was running ok, I initially tested with a basic internet test which worked fine.
Then followed the mqtt example here: https://learn.adafruit.com/mqtt-in-circ ... qtt-broker
thats when it said error regarding the import of ssl??
- Franklin97355
Are you sure you used the airlift code and no the esp32-s2? Post your code if you did.
