Metro M4 Airlift Lite and MQTT project bundle
Martinsoanes
Post by Martinsoanes »
hello Adafruit peeps - a noob looking for some help.
First off, I'm loving the Learn guides, really well done.
I'm running into an issue i cannot find a solution for - I'm trying to use the basic MQTT project guide with a Metro M4 Airlift Lite - following the online guide, running the latest CircuitPython 7.x version and trying to load the basic Project Bundle - upon save/load the serial monitor reports out the following error
File "code.py", line 4, in <module>
ImportError: no module named 'ssl'
I've copied over all the files that i can see included in the download project??? please help a noob by pointing out what i'm doing wrong - much appreciated....
Thanks M
Franklin97355
Re: Metro M4 Airlift Lite and MQTT project bundle
Post by Franklin97355 »
Which guide did you follow and what code did you try to run? Did you load the correct uf2 file and python for V7?
Martinsoanes
thanks - i hope i used the correct references
I first updated the Metro m4 airlift lite from link on this page:
https://learn.adafruit.com/adafruit-met ... bootloader that took me here
https://circuitpython.org/board/metro_m4_airlift_lite/
once the latest uf2 was running ok, I initially tested with a basic internet test which worked fine.
Then followed the mqtt example here: https://learn.adafruit.com/mqtt-in-circ ... qtt-broker
thats when it said error regarding the import of ssl??
Franklin97355
Are you sure you used the airlift code and no the esp32-s2? Post your code if you did.
Return to “Metro, Metro Express, and Grand Central Boards”
