I have an upcoming project where I have to capture data from 2 rs232 devices, temporarily (for a month or so and can then be overwritten) save that data (probably to an sd card) and then output that same data on 2 more rs232 ports.
So I need 4 rs232 ports, a suitable microprocessor board and a suitable storage solution.
I have previously played successfully with a Metro M4 Express AirLift, so I'm considering another of these, but all suggestions welcome. If the hardware can be sourced within the UK that would be a bonus.
cheers
Alex
Hardware suggestions please
- Jeremy97469
Re: Hardware suggestions please
Have you considered the Grand Central M4? It comes with the Micro SD card slot already there. It also has 8 serial ports (SERCOM).
The M4 suggested above would be a good choice .
Note that the serial ports on microcontrollers in general are TTL serial. RS232 uses inverted logic and a higher signal voltage. To communicate with RS232 serial devices you will need an RS232 to TTL converter. SeeedStudio makes a nice one:
https://www.seeedstudio.com/RS-232-To-T ... -2851.html
- nbaever3
I have also the same question that did you considered M4?Jeremy97469 wrote:Have you considered the Grand Central M4? It comes with the Micro SD card slot already there. It also has 8 serial ports (SERCOM).
- AlexJustAlex
Sorry for delayed response, I have been away.
Many thanks for the suggestion I shall be looking into it
Cheers
Alex
Cheers
Alex
